The Lounge A place to talk about almost anything but politics and religion.
Old 2nd February 2013, 07:09 PM   #34081
1audio is offline 1audio  United States
Originally Posted by PMA View Post
Tuned Lynx L22.
That's impressive. And details? Its THD about 15 dB better than the chip seems capable of. On the selftest of the card its not close to those numbers. RightMark Audio Analyzer test : Lynx L22 I would like to duplicate those results as would many here.
Demian Martin
Product Design Services
Old 2nd February 2013, 07:16 PM   #34082
PMA is offline PMA  Europe
PMA's Avatar
BV might tell us more. If I remember well he had swapped some opamps, runs in balanced mode and at optimal I/O levels. Any soundcard needs careful approach to get the best of it.
Old 2nd February 2013, 07:46 PM   #34083
TheShaman is offline TheShaman  Europe
Originally Posted by TheShaman View Post
You don't care about a lot of things, PMA, including measurements - selectively, of course.
Thanks for your input, John.
Quod erat demonstrandum (ὅπερ ἔδει δεῖξαι).
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 2nd February 2013, 08:54 PM   #34084
BV is offline BV  Slovakia
Use I/O levels close to -17dBFS, that´s all. It seems to be optimal level for minimal distortion for L22.
Old 3rd February 2013, 12:11 AM   #34085
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by Tom Danley View Post
Hi Guys
Mr Danley
Yes Group delay plots can show an overall picture, but one needs to focus on the “generic” (acoustic) phase plot http://bksv.at/doc/17-198.pdf while developing a speaker system
I too am convinced that working only on correcting the amplitude part of the measured freq response is -acoustic wise- wrong.
It is the steep curves in the phase response diagram that correlate with problems in the reproduction of transient signals in speech and music.
Regarding your description of Dr. Heyser work, I assume you are describing this (or a refinement of it)
TIME DELAY SPECTROMETER
Originally Posted by kgrlee View Post
I'm surprised to find that I was carrying out similar experiments around the same time Is Linear Phase Worthwhile? though with a rather different slant. My conclusions were very similar.
Ricardo
I don’t have access to AES publications, so I can’t read your paper.
But Blauert's criteria for low frequencies is quite relaxed (around 4ms) compared to mid frequencies GD (0.4ms)
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 3rd February 2013, 12:28 AM   #34086
kgrlee is offline kgrlee
Actually its JC who doesn't care about measurements ... even measurements that he's at pains to tell us ad nauseum, are important like Hirata, Quan & even simple THD & 7th harm.
I'm pleased to see that in Jurassic times, JC actually did measure things but this millenium, he's got out of the habit. And when he does measure things, they are certainly not for the consumption of us Unwashed Masses.
Pavel, on the other hand, has posted many measurements to support his views. Maybe, in the next millenium, JC will do likewise.
Old 3rd February 2013, 12:50 AM   #34087
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
George,
Thanks again for a great read on the transient phase response of loudspeakers. I do believe that we both have the same idea here as regards speaker development. I can't fathom why so many worry so much about a slight phase shift on the electronics side but tend to want to ignore the issue of a much greater magnitude in a loudspeaker. And I also believe that it is the extreme phase shifts in the response plots that are making so many say that we need to remove the upper frequency response of loudspeakers for them to sound good.
John C,
I think that if you go back and read the books by
High Performance Loudspeakers: Martin Colloms: 978047009430
I believe you will see why the majority of dome tweeters have such response problems. There is no perfect solution for the problem but some dome tweeters are much better than others. It really is not much different from trying to use a cone driver to cover the upper frequency response range, the cone breakup modes are just to severe for that to happen and dome tweeters suffer the same fate in the upper frequency range. If domes would actually stay as a dome as we see them things could be different but the shape of the dome doesn't look anything like the rounded dome we think is producing those sounds. It looks more like someone smashing in a dust cap than a dome at higher frequencies.
Old 3rd February 2013, 12:52 AM   #34088
elektroj is offline elektroj  Europe
And please do not quote audiophile magazines impressions, they are useless.
A bit o entertainment:
Audio Reviews
Old 3rd February 2013, 01:10 AM   #34089
Originally Posted by Esperado View Post
Yes, John, pots are EVIL
Those pots in SSL consoles are nothing, compared to number of Blackmer gain cells that the signal must go thru.
Old 3rd February 2013, 01:19 AM   #34090
john curl is offline john curl  United States
john curl's Avatar
thanks Kindhornman. I have a couple of Collom's books on my shelf.
"Condemnation without Examination is Prejudice"
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
