The Lounge A place to talk about almost anything but politics and religion.
Old 1st February 2013, 08:25 PM   #34021
PMA is online now PMA  Europe
PMA's Avatar
I have never designed anything with them. What I know is I did not like the sound. But BV has had enough experience with them, he can tell us.
Old 1st February 2013, 08:37 PM   #34022
john curl is offline john curl  United States
john curl's Avatar
Thanks for your input, PMA. I was afraid that you might not like their sound. '-)
"Condemnation without Examination is Prejudice"
Old 1st February 2013, 08:39 PM   #34023
Esperado is offline Esperado  France
Banned
Originally Posted by BV View Post
Again, THD figures for PGA are for gain diferent (lower than) from 0dB worse, than for 0dB. This not valid for MDAC, nor relay atenuator. .
It seems not logical: they use one switch by step, the same for each, it is not like DACs. So i do not see why distortion wouls change with position of the attenuator. With level of the signal, yes, as MOS are less linear at high level.
May i ask-you the same question ? Can you try to describe the differences you found between all those solutions, on a subjective point of view ?
Old 1st February 2013, 08:48 PM   #34024
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Originally Posted by john curl View Post
Well, what about distortion at other settings? Anybody?
One of the reasons ADevice's converters (AD1955?) won me over - just with the spec sheet - is they had the confidence- the guts - to spec the thd at -60 input !! Not just at 0 level.
Thx-RNMarsh
Old 1st February 2013, 09:08 PM   #34025
Banned
Richard, DACs commute DC. At 0 dB all the steps are used to compose the signal. The distortion is just a factor of precision of the R-2R network.
BV, what was the source impedance, when you got so bad measurements with PGA ?
Old 1st February 2013, 09:40 PM   #34026
BV is offline BV  Slovakia
PGA driven via 33R direct from previous stage (unity gain follower with OA, distortion at this input point was 2 orders lower than at output). Sound diferences against MDAC or relay attenuator -less resolution, something as "sound smog", less details and missing of something that I call "silence between notes". It is difficult to describe with words, subejctive impact can be different. And look at block diagram for PGA in datasheet, here are for sure more switches in action than one by step. Input divider, and feedback network.
Old 1st February 2013, 10:03 PM   #34027
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
Attached is one measurement for preamp with relay attenuator, difference is visible.. I organized more "sessions" and listeners always prefered version with relay attenuator against PGA or DAC regulation. Most audible are difference between PGA or WM8816 against DAC +OA,and again, DAC is superb compared to PGA or WM, difference DAC vs. relay attenuator is more subtle
Did you compare the relay attenuator to switching attenuator?
Possibly avoiding relays, which are magnetic, can be beneficial.
Old 1st February 2013, 10:06 PM   #34028
myhrrhleine is offline myhrrhleine  Belize
myhrrhleine's Avatar
Originally Posted by fas42 View Post
I come from the "chain is only as strong as its weakest ..." line of thinking: chain A is made from 99 links of strength 100, 1 link of strength 50; chain B is made from 100 links of strength 50 - which chain is stronger? In the audio world everyone will put up their hand to say chain A is obviously superior; everything in my experience says it works just that real, hard metal "rope" - that single, lesser link sets the standard for everything else.
Not very palatable, but that's how it works, IME ...
Frank
If you would convert the chain length strength to equivalent THD values and sum them you would see your error.
[Grasshopper]:Old man, how is it that you hear these things?
[master]:Young man, how is it that you do not?
Old 1st February 2013, 10:10 PM   #34029
Banned
Well, there is two switches, i believe, one in the feedback loop cancelling the input one's distortion. They use-it to increase the gain of the amp between 0 and +15dB.
Thank-you for your answer and description, BV, clear enough, and you describe all that i do not like. Strange that i do not experience the same thing.
Old 1st February 2013, 10:10 PM   #34030
On Hiatus
SY's Avatar
This not valid for MDAC, nor relay atenuator. Try it , I tried personaly in last ten years MDAC ( a bit complicated "driving" for dB steps), WM8816, PGA2310, MAS6116 (all very covenient for use), and finally I stick with relay attenutor. It is simply sonically the best solution with best measured parameters.
How did the Levinson measure so well and win the, ahem, listening contest?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
