The Lounge A place to talk about almost anything but politics and religion.
Old 29th January 2013, 08:18 PM   #33841
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
UK is probably too small a distance to bother with DC. In the US there's a DC long line from the Dakotas' (Minnesota?) coal regions to California. I believe there're some in Russia too.
Thanks,
Chris
Old 29th January 2013, 08:37 PM   #33842
Esperado is offline Esperado  France
Banned
Just curious, how did they transform AC to DC motors and dynamos ? And back, Alternators ?
Old 29th January 2013, 08:48 PM   #33843
Here's a pretty cool picture: File:Pole 2 Thyristor Valve.jpg - Wikipedia, the free encyclopedia
but I remember one from _National Geographic_ from about 15 or 20 years ago that was stunning.
Thanks for making me look!
Chris
ps: in the English language Wikipedia, it's under "HVDC".
Old 29th January 2013, 09:04 PM   #33844
Banned
Amazing ! Thank Chris.
Old 29th January 2013, 11:11 PM   #33845
john curl is offline john curl  United States
john curl's Avatar
The Krell did it first! '-)
"Condemnation without Examination is Prejudice"
Old 30th January 2013, 01:11 AM   #33846
fas42 is offline fas42  Australia
Banned
Love that movie ... so impressive with the special effects they managed to conjure up back then ...
Frank
Old 30th January 2013, 01:40 AM   #33847
bcarso is offline bcarso  United States
diyAudio Member RIP
Frank
Yes, a class act indeed. I love that scene as they are walking on the ramp into the generator area.
And in the "control" room:
Captain: What was the power source?
DR. MORBIUS: May I draw your attention to these gages all around here, gentlemen. Their calibrations seem to indicate that they are set in decimal series, each division recording exactly 10 times as many Amperes as the one preceding it. Ten times ten times ten times ten . on and on and on, row after row, gauge after gauge. But, there is no direct wiring that I can discover. However, when I activate this machine it registers infinitesimally, you see down there in the lower left-hand corner. And, then, when I activate the educator here, it registers a little bit more.
Dr. ???: But this much is negligible, the total potential here must be nothing less than astronomical.
DR. MORBIUS: Nothing less, the number ten raised almost literally to the power of infinity.
Old 30th January 2013, 08:38 AM   #33848
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default Multiple ground points outside the home -
Grounding in the home -- between video/cable/internet and audio systems:
Attached is a quick sketch of the problem when there are just two ground points - one at power entrance panel and one at catv entrance (not at same location). When the two systems are connected together via coax cable, ground potential differences will go thru the A-V equipment instead of grounds (lowest R path). This creates noise and also a path for lightning strikes/transients thru equipment. A ground isolation is needed on the cable - such as a video isolation transfomer or cap coupled rf HP filter to break the ground path. However high volt age transients will go thru. So a surge protection device across the cable is also needed (often a gas discharge tube or other suitable device). Thx-RNMarsh
Ground Current bypass.pdf
Ground-Loops.pdf
Old 30th January 2013, 12:01 PM   #33849
DF96 is offline DF96  England
Originally Posted by wrinkle
I thought that the UK supergrid was still AC, it is only the Power share with Europe in undersea cables that is DC.
Yes, UK transmission and distribution is all AC. Interconnectors to other grids are DC for two reasons:
- no need to synchronise frequency
- no AC losses in underground/undersea cables
I suspect (not sure) that AC ground losses may exceed AC radiation losses for overhead lines. The main loss is just ohmic heating in the conductors.
If a long transmission line was forced underground (e.g. due to visual impact in a National Park) then there might be some advantage in using DC. It is a matter of balancing the AC losses in the ground vs. conversion losses in AC/DC converters at each end.
Old 30th January 2013, 12:13 PM   #33850
cliffforrest is offline cliffforrest  United Kingdom
"The main loss is just ohmic heating in the conductors."
Not helped by the use of aluminium wire, for other reasons.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
