The Lounge A place to talk about almost anything but politics and religion.
Old 24th January 2013, 07:44 PM   #33481
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
First one to offer the pcb and BOM/parts gets my order. Thx-RNMarsh
Originally Posted by PMA View Post
Homage to Scott Wurcer:
Old 24th January 2013, 07:50 PM   #33482
PMA is offline PMA  Europe
PMA's Avatar
When not on one chip many of advantages would be lost.
Old 24th January 2013, 07:55 PM   #33483
jcx is offline jcx  United States
back when this thread only had one part I tried a AD797 sim
John Curl's Blowtorch preamplifier
Old 24th January 2013, 08:30 PM   #33484
Esperado is offline Esperado  France
Banned
Originally Posted by RNMarsh View Post
The threshold of thd is about 2-3cm for steel.
Thanks for the precision Richard, it seems i was 1cm too optimistic.
Yes, it seems this thread is sometimes useful.
Old 24th January 2013, 08:53 PM   #33485
jneutron is offline jneutron  United States
jneutron's Avatar
I would assume that the actual distance would be dependent on the impedance of the circuit as well. High impedance circuits will have lower magnetic fields, whereas low z one will have higher..
jn
Old 24th January 2013, 09:44 PM   #33486
john curl is offline john curl  United States
john curl's Avatar
Distance does help, IF you can create the distance.
"Condemnation without Examination is Prejudice"
Old 24th January 2013, 10:07 PM   #33487
fas42 is offline fas42  Australia
Banned
The threshold of thd is about 2-3cm for steel. This was measured and reported on by researchers in Japan a looooong time ago. Thx-RNMarsh
Can anyone point to material researching other behaviours of pieces of iron or steel near audio relevant elements? Examples: a CD player with conventional steel case, large iron weight on top to reduce vibration; a speaker with usual treble driver on top, again with heavy iron weights on top to stabilise unit on supports. In both cases the sound was severely degraded ...
Frank
Old 24th January 2013, 11:01 PM   #33488
gpapag is online now gpapag  Greece
gpapag's Avatar
Originally Posted by jcx View Post
Hofer found some distoriton in his AP sine generator when the steel cover was put in place - the production fix was to add patch of Al sheet to the steel cover over the oscillator region
the Eddy Current "shielding" of the Al sheet knocks down the B reaching the steel
a inverted application of what Ott, others show for severe EMI shielding by layering high conductivity and high mu materials - the Eddy current in the conducive material "shields" (or reflects) anything more than a few skin depth in frequency content, the iron can short out lower frequency that gets through
so maybe audiophiles need to line their steel boxes with thick Al
True and copper would be more effective than aluminum on this.
But it works with HF.
Eddy current shielding needs at least 2, better 3 delta for shield thickness.
Visit the monogram that Richard kindly attached.
Detailed formulae have also been linked to.
As well as an old Bell paper that refers to calculation and measurement of distortion components due to magnetic hysteresis of steel.
The repetition period of visiting the same topic has become alarmingly short (age issue )
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 24th January 2013, 11:04 PM   #33489
gpapag's Avatar
Originally Posted by Esperado View Post
We have a very sadist proverb in France: "The best is the ennemy of the good".
It use to turn in circle in your brain each time you broke some near perfect stuff, trying to do better, mixed with a nice sample of your best insults.
Christophe
If you are referring to the driver I killed, it survived the modifications battle field. It died during measurements (Like:He fell from the stool in the bar and broke his neck).
Thanks to the profound stupidity of mine.
George
Old 24th January 2013, 11:29 PM   #33490
Banned
I envy you, George. With age, i begin to be so upset with all past bad experiences in electronic that i am virtually paralyzed, providing every gesture and its possible consequences before to begin a work. This does prevent nothing, of course, and certainly not Murphy.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
