The Lounge A place to talk about almost anything but politics and religion.
Old 23rd January 2013, 04:38 AM   #33381
PMA is offline PMA  Europe
PMA's Avatar
Please note that OPA637 is stable for gains 5 and higher. So it would not work with integrator-like networks (active MM compensation) that require UGS (unity gain stable) opamps. In such case, OPA627 to be used.
Old 23rd January 2013, 05:30 AM   #33382
Jay is offline Jay  Indonesia
Banned
Electrolux, it sucks!
Old 23rd January 2013, 05:52 AM   #33383
PMA's Avatar
Originally Posted by john curl View Post
There is no such thing as a 'JC-2 Mk-1' design, in my experience. Would you like to clarify your accusations?
Richard means this design (that you have posted):
Old 23rd January 2013, 05:58 AM   #33384
PMA's Avatar
For the record, the IC op amp that I use in place of the AD797 has to amplify over 30 dB or 40 times and has a final load of 800 ohms above 2KHz. Not so easy as some might guess.
They way I tested AD797 (and other opamps) yesterday was quite similar or probably more stressing. Gain 40dB and linear load of 1kohm.
How did you like the National Semiconductor opamp you have used to replace the AD797? BTW, in my measurements the AD797 has lower noise than 4562 and is more resistant to HF interference.
Old 23rd January 2013, 06:07 AM   #33385
john curl is offline john curl  United States
john curl's Avatar
Thanks PMA, I didn't draw the schematic. I think of it as the JC-3, but this was an early version.
"Condemnation without Examination is Prejudice"
Old 23rd January 2013, 07:16 AM   #33386
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by Chris Hornbeck View Post
Thanks very much to PMA for the excellent comparative measurements and for the striking conclusion, that despite these tiny numbers an ordering of sound qualities is still possible.[snip]Thanks again,
Chris
Ohh? I thought we had agreed here that measurements say nothing about sound quality? Are you now saying that the rank of 7th determines the rank of sound quality, even if it is below the -110dB audibility threshold John gave?
To paraphrase: dazed and confused ...
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 23rd January 2013, 07:45 AM   #33387
PMA's Avatar
Default CCIF2 19+20kHz measurement of opamps
Today I have prepared a 2nd set of opamp measurements. Now it is CCIF2, 19+20kHz. Only difference tone (1kHz), i.e. 2nd harmonic component, is calculated in 0.000X% results. But we have the FFT spectra.
Test conditions: Gain = +101 (40dB), Vout = 2.9Vpp, loaded with feedback network 1kohm + 10 ohm. The schematics is in the attached file. I have also added the measurement limit - card loopback measurement. It is another card than yesterday, for it performs better in CCIF2 test.
One can see that AD797, AD844 and OPA637 have had excellent results in this CCIF2 test. OPA134 has higher 3rd order products - the distortion lines close to 19kHz and 20kHz spectral lines.
Regarding THD1kHz and CCIF2 measurements, the winner is AD797. But, as correctly described by Richard, this opamp needs much more care regarding PCB and decoupling layout and is more sensitive to RF interference than JFET input opamps and than AD844 CFA opamp.
Old 23rd January 2013, 09:41 AM   #33388
jan.didden's Avatar
Pavel I wonder how much of this is CM distortion?
Your feedback network is probably to low in value to try in inverting mode?
jan
Old 23rd January 2013, 09:57 AM   #33389
PMA's Avatar
You are perfectly right, Jan. My setup erases influence of CM distortion and non-linear capacitances.
1) Resistors in -IN and +IN are only in tens of ohms. Too low to see non-linear capacitance effect.
2) Gain +101 and output voltage slightly above 1Vrms results in 10mVrms input voltage only. Again, influence of CM distortion is suppressed.
I wanted to measure noise (SNR) - thus low resistance values.
If I measured at gain 1 - 10, the result of good opamps would be below my distortion and noise measurement threshold limit.
So it goes, nothing is perfect.
Old 23rd January 2013, 10:33 AM   #33390
jan.didden's Avatar
Some of those opamps are close enough, technically.
The next frontier is marketing!
jan
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
