The Lounge A place to talk about almost anything but politics and religion.
Old 22nd January 2013, 07:54 PM   #33351
gk7 is offline gk7
Probably this one: The Bastard Operator From Hell Complete
Old 22nd January 2013, 08:17 PM   #33352
Jonathan Bright is offline Jonathan Bright  Australia
John and others; a question about IC's. Like a number of readers (rather than participants) in this thread I am out of my depth with the more technical issues but like the idea of gaining insights so as to modify my own system. You have mentioned the AD825 favorably a couple of times. My question concerns "settling time". About 40 yrs ago Gordon King and JLH in the UK were advocating a low settling time as an important criteria for a good subject response from power amps.
I notice the AD825 DOES have a very low settling time compared to a lot of other IC op'amps.
Has anyone got any thoughts on this as an indication of good subjective sound......?
And if so why.........?
"It was the Springtime of the year when aunt is calling to aunt like mastodons bellowing across primeval swamps." P.G. Wodehouse.
Old 22nd January 2013, 08:41 PM   #33353
john curl is offline john curl  United States
john curl's Avatar
My criteria is: Fet input, wide open loop bandwidth.
"Condemnation without Examination is Prejudice"
Old 22nd January 2013, 08:49 PM   #33354
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by jneutron View Post
Answers.
jn
Thanks for going into the trouble jn
Still in the dark but itís not because of you.
Originally Posted by PMA View Post
If there is anyone interested, here is the complete measurement of opamps + schematics.
Thanks for sharing Pavel.
What is the output level in these measurements and on what load?
Any 5532/5534 on your bench?
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 22nd January 2013, 08:52 PM   #33355
ED Re; graph #33343.
Is it some sort of inverse F-Munson curve?
Old 22nd January 2013, 08:53 PM   #33356
simon7000 is offline simon7000  United States
Bingo! Yes it is. Or a curve of the ear's sensitivity.
Old 22nd January 2013, 08:54 PM   #33357
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by simon7000 View Post
"0.55 pV/Hz1/2, more than
three orders of magnitude lower than would be possible with
the best conventional room-temperature voltage amplifier."
Great, now we gotta do all our recordings in a giant dewar flask.
Not the point, I assume the experimenters were at room temperature. They were able to build an experiment that had <-200dB line contamination, in fact .55pV is almost -246dBV!
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 22nd January 2013, 08:54 PM   #33358
PMA is offline PMA  Europe
PMA's Avatar
George, as already mentioned, output voltage is close to 1Vrms. As shown in the schematics in the document, load is 1k (FB 1k + 10 ohm).
Old 22nd January 2013, 09:08 PM   #33359
kgrlee is offline kgrlee
Originally Posted by john curl View Post
Please give it a break, PMA. 7th harmonic is STILL very important. I challenge YOU to make something better than my designs, rather than 'bad rap' me.
JC, how about measuring or letting someone measure Blowtorch to see how much 7th it has under comparable conditions to AD797 etc. I'm sure Pavel will be happy to do so.
Much more convincing than 'pontificating on your 'calculations'. Have you checked your calculations against Baxandall? He actually measures stuff to confirm his measurements of exactly this effect.
Then I mentioned that I was still thinking of building a solid state 'transformer eliminator' and they 'showed me the door' literally, claiming that their best engineers had claimed it impossible, and therefore I was just some 'nut' wasting their time. ... I had the problem solved in 1968, ... follow the input stage with something elegant, rather than just an add-on circuit. ... Ultimately the Levinson JC-1 appeared with a rated noise of 0.4nV/rt Hz noise at the NY AES in 1973. ... Low noise design has been known about (what to do) for many decades. The problems are: .... If you can do all three, you have a good chance of making a low noise, successful audio design.
Would you like to tell us how with all this supa dupa experience & superior knowledge, you ended up with the original JC2 Mk1 circuit that was caned by the reviewers?
Old 22nd January 2013, 09:13 PM   #33360
But they weren't SY either.
I think way back I showed a -180 result of one of my toys.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
