The Lounge A place to talk about almost anything but politics and religion.
Old 22nd January 2013, 05:29 PM   #33331
jcx is online now jcx  United States
Default please, john, the "poor me" and the arrogance really don't mix well
feedback only works well for a fairly linear open loop - can't magically bridge a deadband only try to push faster trough it - with limited success
but the when the amp is free of deadband, abrupt gain changes then feedback over a certain level does reduce all orders of "locally Lipschitz" nonlinearities where the feedback factor is large
and much of the pious "make the amp as linear as possible before applying feedback" is in reality just choosing how to distribute feedback between local, and larger loops up to the global feedback
once you have decided how many, what type and how heavily biased the gain elements are
op amp open loop linearity plots are rare, but appeared at least 3 decades ago in some (PMI) datasheets - Pease has written on this - published test circuits, plots - it really is text book (or app note) engineering today
if monolith op amp designers don't show you then measure it, if they choose too low bias current, too small output Q, then bias, buffer the output if you like the rest of the specs - if not pass it by
you could even look at less than 20 yr old op amps
Old 22nd January 2013, 05:37 PM   #33332
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Default -200dB and no mains noise
Here's an interesting physics paper. Notice the noise graphs, no mains lines at all. http://physics.syr.edu/~bplourde/pap...-voltmeter.pdf
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 22nd January 2013, 05:39 PM   #33333
kamis is offline kamis  Serbia
Originally Posted by john curl View Post
For the record, the IC op amp that I use in place of the AD797 has to amplify over 30 dB or 40 times and has a final load of 800 ohms above 2KHz. Not so easy as some might guess.
It should and must only be LME 49990 Ic.
Old 22nd January 2013, 05:43 PM   #33334
john curl is offline john curl  United States
john curl's Avatar
Right you are!
"Condemnation without Examination is Prejudice"
Old 22nd January 2013, 05:48 PM   #33335
gk7 is offline gk7
Originally Posted by SY View Post
...apparently incorrect claim that it is what distinguishes ICs from discrete, relegating the former to "mid fi."
No one doubts that AD797 and OPA637 are excellent (and comparably expensive) parts but you won´t
find them in "mid fi" where the design decisions are made by bean counters.
Would be interesting to see the results for JRC4580 and similar dual opamps you
typically find in consumer gear. (But maybe PMA does not store such junk in his lab. ;-) )
Old 22nd January 2013, 05:59 PM   #33336
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Another *possible* description (not testable AFAIK, so not even a hypothesis) is that intrinsic linearity, before even local feedback, is important. Sounds wacky at first blush, but does go a long way towards explaining such strange things as the ease with which good sound is obtained with vacuum valves, the SET phenomenon, folks' preference for FETs, etc. Maybe it's all self-delusion, but maybe there's some there there.
Thanks,
Chris
Old 22nd January 2013, 06:02 PM   #33337
bcarso is offline bcarso  United States
diyAudio Member RIP
Yes, Chris and jcx say sooth.
In a given small-enough region of operation, our assumptions are that a series expansion of some number of terms accurately describes the nature of the beast, and when feedback is applied it reduces distortion in a predictable way. Thus we are allowed to do the measurements with high noise gain and extrapolate to much lower gains. And the curve of growth of higher-order terms is likewise predictable as a function of level.
Old 22nd January 2013, 06:11 PM   #33338
diyAudio Member RIP
Thanks,
Chris
I'm sure you've seen the theoretical paper of Boyk and Sussman that's floating around, afaik never published in a journal although looking journal-ready to these eyes at least. Sussman is a technical heavy hitter, apparent from his publications and attested to by Scott W.
They deal with ideal models, with appropriate qualification, of FETs, bipolars, and tubes, and look at IM distortion terms arising from very simple structures with local feedback. Someone will have the ref link I'm sure, or I can dig it up.
But in essence, it's a kind of elaboration of the old Baxandall stuff about higher order terms of HD appearing with small amounts of feedback around nonlinear systems, even though the overall performance by some measures is enhanced.
I suspect the focus on IMD, versus HD, makes it a little more relevant to what we seek.
Old 22nd January 2013, 06:12 PM   #33339
And we assume monotonicity.
Thanks,
Chris
Old 22nd January 2013, 06:12 PM   #33340
PMA is offline PMA  Europe
PMA's Avatar
No I do not . But the last page of my zip/pdf that was posted here several hours ago shows uA748. Or precisely MAA748, the Tesla equivalent of uA748, with Ccomp 10pF, which makes it faster than uA741 (equals Ccomp 30pF). If you want to laugh, here it goes again: (noisy and with THD increasing fast with frequency)
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
