The Lounge A place to talk about almost anything but politics and religion.
Old 19th January 2013, 06:10 PM   #32981
On Hiatus
SY's Avatar
Originally Posted by Waly View Post
You would pull anything out of thin air to make a point, isn't it?
Even with cheating, the number is ridiculously low.
The tip o' the hat to John is Ed's use of 1968 components for examples, so even my numbers were enormously higher noise than you get from modern ICs.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th January 2013, 06:22 PM   #32982
Esperado is offline Esperado  France
Banned
Ampex ATR-102 half-inch two-track, (not modified by John curl :-) with extended low frequency heads, 30 IPS. This is at Studio X in Seattle.
And this a Pc based with Starmax MT3200 computer's onboard A/D converter
Old 19th January 2013, 06:23 PM   #32983
john curl is offline john curl  United States
john curl's Avatar
What I like best is the 1966 voltage regulators made by National. They were quieter than almost anything, today!
"Condemnation without Examination is Prejudice"
Old 19th January 2013, 06:24 PM   #32984
john curl's Avatar
Great bass with digital. Too bad about the higher frequencies.
Old 19th January 2013, 06:37 PM   #32985
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
To rephrase a point JC was making ---
1. The IC's neg feedback network is in parallel with its load Z ... giving a much lower Z than the input of the power amp would imply.
2. In order to obtain the noise level spec of the IC, it would need very low Z in the neg feedback network.
3. low Z feedback network reduces the max output in the spec sheet.
4. You cant get all the specs in one circuit with fixed values.
have I got that right, JC?
-Thx- RNMarsh
Old 19th January 2013, 06:38 PM   #32986
Banned
This is a 48 KHz recording. Double the frequency for a 96, quadruple with a 192kHz, while i doubt you will hear any listening difference.
May-be asking your dog on his paws crafted enclosures ?
Old 19th January 2013, 06:39 PM   #32987
john curl's Avatar
Thanks Richard. A-OK
Old 19th January 2013, 06:40 PM   #32988
john curl's Avatar
My analog tape recorders could record to 45KHz, so there! '-)
Old 19th January 2013, 06:48 PM   #32989
Waly is offline Waly  Umm al-Qaiwan
Waly's Avatar
Hear, hear, the golden 60's .
Ever tried the TPS7A470 and it's negative version TPS7A3301? 16uV noise in 100KHz BW, one order of magnitude lower than the National 60's negative regulators. And 4uV for the positive version.
Old 19th January 2013, 06:54 PM   #32990
Banned
You yet knew all that very well, Richard :-)
This said, we can notice that, when we need gain and low noise, we do not need high output levels and currents, and when we need current for output buffers, we do not have to care too much about gain or noise.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
