The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 19th January 2013, 08:12 AM   #32941
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Originally Posted by john curl View Post
SACD's or better, for me. '-)
Jan, just got Vol. 3, thanks.
Good! I am all for 'education permanente' as the French say
jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher
Old 19th January 2013, 08:17 AM   #32942
jan.didden's Avatar
Originally Posted by stinius View Post
Gentlemen please remember that the measurements shown by JC are made ​​by Samuel Groner / Weiss.
For those interested that haven't seen the measurements, go to Samuel's homepage and download the (op_amp distortion.pdf), (too large to attach)
IMHO Samuel is trying as much as possible to kill all IC OpAmps, why?
Remember that he is working for WEISS and that they have a their own solution. Their own discrete OpAmp.
Think about it.
Stein
Stein, funny you say this. If you are so concerned about conflict of interest, you should start to delete ALL posts in this forum by people who are in the industry. Sorry JC, sorry Scott, Richard, bear - you all have double agenda's can't have that, all your posts pooof...
jan
Old 19th January 2013, 10:22 AM   #32943
On Hiatus
SY's Avatar
Originally Posted by RNMarsh View Post
Give up guys.... you've tried for months and years to get JC to compare distortion numbers and means and methods... he isnt going to do it. IMO comparing thd and noise and bandwidth becomes a numbers game for marketing. JC has said he belivevs there is more to better audio performance than only those numbers.
The problem is that John explicitly said that competitive preamps using IC opamps were "mid-fi" because of higher 7th and 9th harmonic levels compared to the equipment that his "team" designs. That is an objective, numbers-based claim.
Maybe it's just me and my silly stiff-necked sense of honesty, but if I claimed a performance shortfall for products which competed with mine, I'd have data to back it up or be willing to retract my claim. The fashion audio world is apparently different...
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th January 2013, 10:44 AM   #32944
On Hiatus
SY's Avatar
For everyone to more completely understand:
Analog magnetic tape IDEALLY doubles in distortion for every 3dB rise in level. Of course, it decreases in the same amount for every 3dB fall in level.
This follows the mathematical law of generating 3'rd harmonic distortion.
So: 6dB rise gives 4 times more, 10dB rise gives 10 times more.
With high speed tape, it is VERY consistent with this prediction.
That's fine, but what evidence do you have that this is applicable to preamps?
If arguendo we use your calculational method to look at a 797 in the distortion magnification mode used by SG (which is unreasonable), for the same signal levels you asserted for the BT (which I agree are reasonable and are 20dB below SG's level), and a 600R load (which is unreasonable), the 7th harmonic would be at (-113dB - 6{20dB}) = -233dB. I think even Ed would strain at that one.
Your assertion continues to ring false.
Old 19th January 2013, 10:50 AM   #32945
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by SY View Post
T
Even if it was only -500dB, the 7th is an Evil!!
Old 19th January 2013, 12:54 PM   #32946
DF96 is online now DF96  England
First of all: ANY open loop system that is also Class A has a predictable distortion curve, ONCE you get an accurate set of measurements at some typical level. You can go both up or down in level and PREDICT the distortion with a great degree of accuracy.
Come on everybody, look it up in a textbook on non-linear circuit analysis.
Let me give an example of how I would (and do) estimate distortion in an open loop, Class A system:
First, I get a set of exact measurements of each harmonic at some part of the operating level within the design parameters of the design, i.e. NO pre-clipping levels, as this will throw off the estimate.
Then: For 2'nd harmonic, estimate that its value drops directly with voltage level.
For 3'rd harmonic, estimate that its value drops directly with the SQUARE of the voltage level.
For 4'th harmonic, estimate that it drops to the CUBE of the voltage level.
Etc, etc.
Now what about 7th harmonic? It should drop as the 6th power, which implies that if you drop the voltage level in 1/2, then the 7th harmonic should drop by a factor of 64.
Almost true, John. However, it is not enough to be below clipping - you also need to be below the level where, say, 7th order nonlinearity contributes significantly to 3rd order distortion. Therefore you need a set of measurements at different signal levels which demonstrate that this is true. Provided your set of measurements roughly follow the power law you describe, then you can fairly reliably extrapolate downwards.
There also has to be an assumption that there are no low-level effects in contacts etc. No point in having Class A devices with Class B wiring! Except under fault conditions I doubt that such things are a problem, but some people worry about them.
Old 19th January 2013, 12:58 PM   #32947
TheShaman is offline TheShaman  Europe
For some its the 7th, for others its Class D amps. Everyone has his phobias I guess.
...usually defined as a persistent fear of an object or situation in which the sufferer commits to great lengths in avoiding, typically disproportional to the actual danger posed, often being recognized as irrational.
Phobia - Wikipedia, the free encyclopedia
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 19th January 2013, 01:45 PM   #32948
Esperado is offline Esperado  France
Banned
I was exposed to it for many years with analog tape recording, in which the 3'rd harmonic (totally dominant because of the tape itself) could be reliably predicted, over and over, with different recording levels, once a single distortion with level was measured.
I am VERY surprised to read that under your pen John. When we arrive near the saturation of the tape, the response curve begin to change. ~0dB is the max level you can achieve at 10hHz and 15 Ips, right ? While you have more than 10dB more available under. So the harmonic distortion is not linear at all, and the higher harmonics decrease, there, where the level increase.
It explain the "hot" sound with tape on hight transients.
I used sometimes, to clip the kick drum, and record-it that way on tape at VERY high level: Tape's saturation removed all the high harmonics, and gave a very natural 'kick' attack, even when the original sound was dull and just resonant with not enough transient. You were not able to hear distortion, just what you believe is the hit of the beater on the skin, while the sound from the desk was awfully saturated.
Originally Posted by a.wayne View Post
Very little between 15 and 30 ips ....
Reason why 15 Ips was chosen as the standart professional speed for tape recording.
Old 19th January 2013, 01:55 PM   #32949
john curl is offline john curl  United States
john curl's Avatar
First, let's address 7th harmonic. Here is a small article on the subject. I didn't invent the problem, just noted it. It took me less than 5 minutes to find it with 'Google'.
"Condemnation without Examination is Prejudice"
Old 19th January 2013, 02:03 PM   #32950
Banned
Because dominant 7th chord was named "diabolus in musica" ?
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
