The Lounge A place to talk about almost anything but politics and religion.
Old 18th January 2013, 02:11 PM   #32871
Esperado is offline Esperado  France
Banned
John, something would be interesting to allow us to get a physical idea of your mythic Blowtorch.
To record a sample of any CD, out of the analog out of your preferred player, and the same out of your Blowtorch and provide the files.
What do-you think ?
Old 18th January 2013, 02:12 PM   #32872
john curl is offline john curl  United States
john curl's Avatar
Here is an example of the JC-3 early prototype. Please note loading of AD797, and use of constant current jfets on output to give more Class A range.
"Condemnation without Examination is Prejudice"
Old 18th January 2013, 02:13 PM   #32873
john curl's Avatar
I don't do CD's. '-)
Old 18th January 2013, 02:38 PM   #32874
On Hiatus
SY's Avatar
Originally Posted by Bonsai View Post
NO!!
John said very explicitly that it is, and that it's this supposed defect which relegates IC-based preamps to "mid-fi," unsuitable for discerning ears. I await either his supporting data or his "oops, I was mistaken, thanks for the correction."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th January 2013, 02:57 PM   #32875
Banned
http://us.123rf.com/400wm/400/400/do...-en-studio.jpg
Old 18th January 2013, 04:50 PM   #32876
john curl's Avatar
SACD's or better, for me. '-)
Jan, just got Vol. 3, thanks.
Old 18th January 2013, 04:53 PM   #32877
Banned
SACD is not a CD ? You like to play on words, or what ?
The correct orthography is SA-CD and means Super Audio... CD.
Old 18th January 2013, 04:57 PM   #32878
john curl's Avatar
To me, there is: CD, DVD 24/96, SACD, and now even higher sampling rates coming off the press. CD sucks. DVD and SACD, OK, and I hope for even better.
WHY would I bother with what I bother with in audio, if I was stuck with CD, only?
Old 18th January 2013, 05:04 PM   #32879
jcx is online now jcx  United States
Default rhetorical, much?
no they're DVD with funny servo track coding for anti-piracy, 4x the bit rate of RedBook CD
with the additional fun of being single bit DSD - basically a "noise modulated" ~ MHz carrier >+ 6 dB re audio fs
the only way to get the 120 dB noise spec at 20 kHz is to use >5th order negative feedback in the noise shaping process
so of course it is considered "more analog sounding" - wasn't that easy to predict from the tech details?
Old 18th January 2013, 05:04 PM   #32880
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Default cool idea dept -
Take a wide band, high slew rate amplifier - implying low-med nfb circuit - and add a comparator to the I/O and feed the comparator output back into an amplifier input to cancel remaining distortion. Works very well, it seems from data shown. Some old guy from France named Christophe showed this in another DIYAudio forum. Very cool, IMO. Thx, RNMarsh
Last edited by RNMarsh; 18th January 2013 at 05:11 PM. Reason: Very cool idea applied to audio -
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
