The Lounge A place to talk about almost anything but politics and religion.
Old 16th January 2013, 02:55 PM   #32751
DF96 is offline DF96  England
Coax symmetry is not the problem. The issue with coax is that the spacing between inner and outer is large enough that normal skin effect dominates. Now I believe that skin effect and proximity effect are merely auto and mutual versions (respectively) of the same thing so will behave in the same way, but I am not sure everyone agrees so demonstrating nothing strange with skin effect might not convince those looking for strange proximity effects.
You would probably need to setup something where conductor spacing is smaller than skin depth so proximity effect dominates, as may sometimes be the case for audio. Maybe an air-cored inductor or transformer, but with well-encapsulated windings so no physical movement is possible?
Old 16th January 2013, 03:08 PM   #32752
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by scott wurcer View Post
One rule NEVER ever sign an NDA with kooks.
Earnest inventors often wonder why large companies turn them away when they show up at the door with big grins and "great new ideas".
My other favorite are the calls I get from people with "great ideas" who in essence wind up saying "with my great idea, and your expertise to make it work, we'll split 50-50 and both get rich!"
Old 16th January 2013, 03:25 PM   #32753
Esperado is offline Esperado  France
Banned
Don't they realize the simple fact they ring the door's bell is an insult to the manager of the company and the money he invested in the R&D department ?
Old 16th January 2013, 03:44 PM   #32754
mikelm is offline mikelm  England
Send a message via Yahoo to mikelm
Don't the managers realise that their "not invented here" closed minded attitude probably loses them some unique opportunities - other side of the coin
Old 16th January 2013, 03:55 PM   #32755
Banned
I agree, with the eyes stuck on daily work and efficiency requisites, a R&D department is often the worse place to get innovative ideas. Even if it is in your nature to look at the things upside down. Part of the Peter principle.
Old 16th January 2013, 04:39 PM   #32756
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by magnoman View Post
George
At least for the current crowding effect being discussed wouldnt the co-ax symmetry prevent it all together?
-Antonio
Antonio , as DF96 said this symmetry is not the problem.
The "current crowding" effect in the coaxial expresses itself as current concentrating at the outermost of centre conductor’s diameter and at the innermost of shield’s diameter. At both conductors, the cross-sectional current carrying area diminishes.
This is my understanding too
That’s an invitation for discussion
The issue with coax is that the spacing between inner and outer is large enough.
The beauty and convenience of theoretical approach is that this distance can be made minute. Distortions (if any) can be theoretically derived. Effect of radial distance increase up to a real physical size can be calculated.
On the theoretical level of approach, the study is done on the cross section of the coaxial line, i.e. a slice having an axial length dL.
If result are then integrated over a length 1000dL or 100000dL the calculated distortions at the dL slice will I guess be multiplied accordingly (?).
Then, a good length of a coaxial cable with a small diameter (e.g. RG58) can be used in experiments to test the theoretical predictions.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 16th January 2013, 04:41 PM   #32757
john curl is online now john curl  United States
john curl's Avatar
I remember back in 1975 while attending an AV convention in Montreux, I tried to interest Neve 'engineers' in my measurements of the ceramic caps that they were using in their modules at the time. I got a big affront telling me that everything they do is a 'trade-secret' and they don't wish to discuss any new input. '-)
"Condemnation without Examination is Prejudice"
Old 16th January 2013, 04:44 PM   #32758
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
jn,
That would help but I think I'm following your basic argument just not quite how it produces a second.
If one accepts the dI/dT dependency and that this effect only increases the crowding resistance then I can understand how for a sinewave this would result in cos modulation from the dI/dT and the absolute value to account for only increasing resistance.
But from there I see this modulation producing steeper slopes around the cross-overs, local minimums at the peaks, all symmetrical between positive and negative going cycles of the sinewave. Why wouldn't this symmetry measure as a dominant 3rd?
Real or not at least for a series feedback divider the effects should cancel out (between the high side and low side resistors).
-Antonio
Well easy enough to plot the FFT's, for an R = Ro(1 + a*abs(cos(wt)) there are all even harmonics but sin(wt)/(Ro(1 + a*abs(cos(wt)) ) is all odd. Where a is some very small factor.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 16th January 2013, 04:47 PM   #32759
On Hiatus
SY's Avatar
That one has me scratching my head in puzzlement. The barrier to accepting ideas thrown over the transom (besides the obvious, that most of them are a colossal waste of time) is that if the idea is a good one, you're 99.99% certain to end up in expensive litigation even if it's an idea that already existed within the company. I've worked in and run several different R&D organizations and there's no shortage of really interesting and original ideas that come out of them.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 16th January 2013, 04:55 PM   #32760
diyAudio Member RIP
Originally Posted by SY View Post
That one has me scratching my head in puzzlement. The barrier to accepting ideas thrown over the transom (besides the obvious, that most of them are a colossal waste of time) is that if the idea is a good one, you're 99.99% certain to end up in expensive litigation even if it's an idea that already existed within the company. I'veworked in and run several different R&D organizations and there's no shortage of really interesting and original idea that come out of them.
Litigation, or rather its avoidance, is really the key here. It is sooo expensive, in money but especially in time, even if you "win". And there is a natural but often unjustified notion that the "big" company is simply at fault to begin with. Sometimes they are, and being big does often engender arrogance and worse. But the romantic paradigm of the little guy getting the helical inclined plane (or however the writers of Big Bang Theory put it) is also not always accurate.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
