The Lounge A place to talk about almost anything but politics and religion.
Old 10th January 2013, 09:00 PM   #32481
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by DF96 View Post
Proximity effect is just the mutual version of skin effect (i.e. self-proximity). Skin effect is linear, therefore proximity effect is too.
Think of it within the context of figure 3. The loop area modulation and therefore the resistance, is a function of the absolute value of the current slew.
Proximity effect modulation of a cylindrical resistor's resistance is a function of the absolute value of the current derivative.
jn
Old 10th January 2013, 09:17 PM   #32482
john curl is offline john curl  United States
john curl's Avatar
V/nS?
"Condemnation without Examination is Prejudice"
Old 10th January 2013, 09:25 PM   #32483
DF96 is offline DF96  England
Skin effect and proximity effect arise from Maxwell's equations and the 3-D version of Ohm's Law. These are linear. Therefore any solution must be linear.
Old 10th January 2013, 09:27 PM   #32484
jneutron's Avatar
Review the equations. Find the absolute value "clause".
jn
Old 10th January 2013, 09:30 PM   #32485
simon7000 is offline simon7000  United States
Originally Posted by scott wurcer View Post
Excuse me, these numbers are at G = <PLUS>1, the distortion making resistors must be imaginary. There is no current flowing in Rf in figure 4 save the (101x the error signal)/Rf. Come on guys, pay attention. Ed you mis-understood my joke, you said the thermal distortion was third order for a DRY resistor.
C'mon Scott, you know the drill. They are looking at the difference across a 10 ohm resistor with a gain of 100. The noise from just the resistor should be (back of envelope calc's) 100pV/Hz at the input. Add this to the 2.7 nV/Hz and you get 2.702 nV/Hz. (For those who have trouble with this addition please do a bit of homework before commenting.) With a gain of 100 that is 270.2 nV/Hz of noise. Now .00003% of 5 volts is 1.5 uV. So (1.5 uV/270.2 nV)^2 is a measurement bandwidth of 31 Hz.
Now they are measuring using an AP System 2, something I am familiar with. If I just go to the FFT analysis without stepping up the default resolution this level wouldn't even show up. Now at maximum rate the AP does go to -150ish re 1 V rms. But that takes 45 minutes or so. Without details on the settings of the AP one does not know if they were looking at noise or signal.
When they first did their setup they used higher value resistors. (So please don't give me they know what they are doing line... everyone makes missteaks.) I did tease BP about it and never got a reply, but the next time I looked they were using much lower value resistors.
ES
Old 10th January 2013, 09:31 PM   #32486
jneutron's Avatar
Originally Posted by john curl View Post
V/nS?
In Ed's test setup? No. I've delved in components and test setups using 400 V/nS with 8 amps per nanosecond, where the effects were right there in your face/slap you upside the head. But I've no access to an AP to try this at the low levels necessary in audio.
Let Ed do the test (if he wishes). It would be nice to confirm or refute a proximity based resistance modulation as applied to audio level signals and components.
jn
Old 10th January 2013, 09:37 PM   #32487
Old 10th January 2013, 09:41 PM   #32488
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
ES
What math? This circuit works as shown just fine a 65k FFT has about 1Hz noise BW and the distortion components are easily resolved. Ed the 1.5uV is also X101 to the output not just the noise. 1.5uV of thirds is 150uV at the output (that's the point of the circuit) the noise in a 1Hz BW is ~.27uV. I think Bob Pease included the pictures when he did it.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 10th January 2013, 09:46 PM   #32489
Think one frequency in the Fourier domain the derivative has both signs, but it makes no physical sense to subtract AND add resistance by constriction of path. So I see seconds, sort of a rectifying mechanism.
Old 10th January 2013, 09:52 PM   #32490
jneutron's Avatar
Examine figure 3 again. Pretend the conductor they show is actually cylindrical in shape. Pretend it is skinning as they depict, such that current is flowing on the surface. Then pretend that there is a return current right next to it such that the current on the cylinder is closest to the return conductor. In other words, substitute a cylinder for their rectangular section.
Now, is the picture of positive going current or negative going current?
The answer is, it is a depiction of current crowding INDEPENDENT of the direction in which the current is changing.
That is the "clause" I refer to.
The resistance of the cylindrical resistor can be modulated higher than the base resistance by the proximity effect. It CANNOT be modulated to be lower than the base resistance.
The resistance will modulate in only one direction. Given sine wave excitation and cosine slew, the resistance will modulate based on the absolute value of the cosine slew.
jn
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
