The Lounge A place to talk about almost anything but politics and religion.
Old 8th January 2013, 07:48 AM   #32331
TheShaman is offline TheShaman  Europe
Originally Posted by abraxalito View Post
From an engineering perspective, seconded without any doubt. From a marketing perspective the jury's still out - let's see how Mola Mola gets on...
Haha, yeah, I sure hope there is someone else doing the marketing.
"You have a hierarchy: a mathematician, a physicist (which is a failed mathematician), and an engineer (which is a failed physicist)." - Andrew Jones
Old 8th January 2013, 07:54 AM   #32332
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
ROFLMAO - let's drink to that
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 8th January 2013, 08:41 AM   #32333
gpapag is offline gpapag  Greece
gpapag's Avatar
I too can name many stuff
Good post Shaman syntekne
I trust Pavel will present us his chip amps dragons and class D demons , mostly these that are relevant to audio performance.
If not, I would say he drifts toward the “all you amateurs out there” mode.
George
PS. Shaman, who is this Andrew Jones at your signature? Did he provide adequate evidence for the quote?
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 8th January 2013, 08:48 AM   #32334
abraxalito's Avatar
George - its this one - andrew jones
As for Mola-Mola - here : http://www.audiophilejournal.com/mol...s-d-amplifier/
Old 8th January 2013, 08:48 AM   #32335
gpapag's Avatar
Marketing perspective eh? You are asking for trouble!
Who might Mola Mola be?
George
Old 8th January 2013, 09:09 AM   #32336
Esperado is offline Esperado  France
Banned
Originally Posted by ticknpop View Post
I heard the Cabasse Sphere last year. It was loud and generally annoying the several times I heard over 2 days. It imaged in a rather interesting coherent manner, but it lacked finesse and detail.
Never hear them. But i'm surprised by your comments, i remember Cabasse produced *very good* Hifi enclosures in the 80s.
As they are equalized by an active filter, something was tuned in a bad way ?
What was the problem, lack of dynamic ?
Anyway, i was not referring to them for their sound, but the innovation's attempts. At least several things are perfect on an acoustical point of view: Spherical enclosure, coaxial drivers.
Old 8th January 2013, 09:24 AM   #32337
Banned
Originally Posted by vacuphile View Post
Telstar, with pleasure.
When the circumpherence of a piston is equal in size to one wavelength of sound, it enters the piston band, and for frequencies above, the radiation pattern begins to narrow or beam. The mechanisme behind this is that sound waves emanating from opposite sides of the driver start to interfere at a certain angle off axis.
With a d'Appolito setup, this beaming is assymetrical. Beaming will start on the vertical axis well before it starts in the horizontal plane. When you do the calculations for two 5" midwoofers, you will find that you need to cross over unrealistically low in order to prevent excessive beaming on the vertical axis.
This is the first reason why in my experience only small d'Appolito's work.
The second has to do with lobing as a result of the xover between mid and tweeter. The larger the acoustic distance between the two drivers, the narrower the central lobe becomes. This compounds the problem of beaming as mentioned before. Again a reason to keep it small.
The advantages can be twofold. The first one is that two coincident sound sources add up to +6dB, whereas the electrical energy put into it only doubles. 3dB of efficiency gain for the cost of one extra driver. This directly translates into less distortion. The second is that the vertical beaming can be put to some use, if controlled. .
This is an other way to explain what i said, i agree on all. With a detail, acoustic level at xover will not add 6db at high frequencies, but only ~3db.
I insisted several time, here, about the importance for the two speakers of the two ways, at the Xover, to have the same radiating diameter. Reason why i prefer horns.
The try of a more WAF enclosure for Aeria sytems:
MHP (la Maison du Haut-Parleur) : concepteur français de kits d'enceintes pour la HI-FI et le Home Cinéma...
finished in my home that way despite all the expected advantage of smaller diameter bass drivers (Upper cutoff frequency)
Old 8th January 2013, 11:46 AM   #32338
Hi George,
This is the 2-part interview of Andrew Jones (Director and Chief Engineer of TAD Laboratories) I got the quote from:
Andrew Jones of Technical Audio Devices - Part one
Andrew Jones of Technical Audio Devices - Part two
Very interesting read IMHO. Has a lot of info about his life/career as well.
He's not a mathematician.
Old 8th January 2013, 01:21 PM   #32339
Banned
Interesting interview, this guy is clever, not pedant and sympathetic. :-)
At the end, i wonder why designing for audio is so painful, with traps on every way you walk in.
Where each new track you can imagine to get rid of an inconvenience brings this own lot of negative effects.
Old 8th January 2013, 02:28 PM   #32340
gpapag's Avatar
There is hope in this life.
Engineers (these lowest level creatures) can have humour!
Shaman, thank you for the links. He is very good.
Excellent read.
Quite many points in there, have been addressed by Esperado and kgrlee here.
George
>Edit. Can anyone link to these papers of the "multi-source Uni-Q experiment" at KEF?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
