The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 3rd January 2013, 06:21 PM   #32181
simon7000 is offline simon7000  United States
Originally Posted by Esperado View Post
Adding two paralleled diodes upside down between the center transformer wire and ground ?
Correct! Now who did it first?
Old 3rd January 2013, 06:27 PM   #32182
Originally Posted by simon7000 View Post
Pavel,
Would you care to start the list of all the advantages?
ES
Originally Posted by sofaspud View Post
It was unclear to me also, but is now making sense. I'd be interested if there is more to the story.
Originally Posted by SY View Post
You'll want to consider primary and secondary common and differential mode filtering, interwinding shielding, and snubbing (especially the secondaries). A broad-based approach to making quiet supplies is more effective than just focusing on one or two aspects and trying to rhodium plate them.
SY,
Do you care to elaborate on your additions to the list?
I am not big fan of inter-winding shielding as it does increase line coupling to the shield which creates the problem of where do you return those currents. I prefer dual or split bobbin designs and isolating the core from the chassis. (See a Citation 12 for an example.)
ES
Old 3rd January 2013, 06:27 PM   #32183
Esperado is offline Esperado  France
Banned
J.C. ? He did everything first.
I wonder why R core are so rare and expensive, that is the best solution and easy to manufacture.
Old 3rd January 2013, 06:28 PM   #32184
a.wayne is offline a.wayne  United States
Sin Bin
Borbely .....
Old 3rd January 2013, 06:37 PM   #32185
On Hiatus
SY's Avatar
Chassis. It's not a problem, it's a feature. See, for example, how I did this in my phono and line preamp designs which are extremely quiet and don't have issues with line noise pickup at any levels above ridiculous.
There's an excellent and thorough treatment of these issues (as well as the others I mentioned which don't seem to concern John) in "Valve Amplifiers" 4th ed. You'll also see an excellent survey of proper ways to do snubbing in an upcoming Linear Audio (I think the next issue).
Agreed, split bobbin is a great way to go. That's even more important in tube amps, which have some unique ways for noise to creep in.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 3rd January 2013, 06:37 PM   #32186
Originally Posted by a.wayne View Post
Borbely .....
Borberly showed amazing ability to spot an improvement, redo it with his style and present it. But the first place I ever saw it was.... well I won't feed John's ego!
Old 3rd January 2013, 06:46 PM   #32187
But SY you know I go for ridiculous levels!
Bipolar junction transistors are much more susceptible to the problem than red hots. The consumer electronics industry is going to double insulated and plastic chassis. So the current design trend is to use different shielding techniques.
Now Rick Miller mentioned using higher voltage diodes as they have less capacitance than lower voltage types. What was not mention is the difference in switch off voltage between the two, attached is a shot showing the difference between a 1N4004 rated at 400 PIV and 1 amp versus a 2.5 amp 1000 volt generic replacement diode.
Very little difference. It is getting harder to find soft recovery diodes and from my measurements commodity diodes are getting much quieter.
So what else do you want to expand on?
Old 3rd January 2013, 07:01 PM   #32188
bcarso is offline bcarso  United States
diyAudio Member RIP
Although the forward drop is considerably higher, SiC is quite impressive. I wish they made some small ones. Ditto GaN.
Pease once pointed out that many (he may have said "all") silicon schottkies had a "parasitic" P-N junction diode along for the ride, which spoils the fine-structure in reverse recovery.
Old 3rd January 2013, 07:06 PM   #32189
PMA is offline PMA  Europe
PMA's Avatar
I don't think he's ready for his close up, Mr. DeMille.
Old 3rd January 2013, 07:13 PM   #32190
On Hiatus
SY's Avatar
Nothing, really. These are solved problems, and people who want to read about them have plenty of resources; I'm sure your review will be interesting and educational.
Diode switching can be handled with proper snubbing and layout. Having soft recovery makes that easier, and these days, soft recovery diodes are dead cheap. Circuit design and layout for noise rejection is even more important, but doesn't make good stories, apparently.
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
