The Lounge A place to talk about almost anything but politics and religion.
Old 2nd January 2013, 06:34 PM   #32141
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally Posted by bcarso View Post
Yes, that is a time-honored technique that I've used as well, despite the extra diode drops.
I guess I was just puzzled that you introduced (or re-introduced) the subject at this point. But as you say, the concept of a thread topic is long gone.
ThorstenL, (Kuei Yang Wang) advocated this in the long past.
There is also a dedicated thread. Pay attention to Fred Dickmann contribution (post #38)
http://www.diyaudio.com/forums/chip-...tml#post143874
Of course, apart from more balanced loading of the separated secondary windings, it all boils down to better defined return paths (hello jneutron ! )
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 2nd January 2013, 07:05 PM   #32142
john curl is offline john curl  United States
john curl's Avatar
Thanks for the input, Ed, Brad, and others. Yes, I use the dual bridge in the CTC Blowtorch.
"Condemnation without Examination is Prejudice"
Old 2nd January 2013, 07:05 PM   #32143
PMA is offline PMA  Europe
PMA's Avatar
Advantages of 2 bridges have been known for a long, long, long time.
Old 2nd January 2013, 07:20 PM   #32144
simon7000 is offline simon7000  United States
Pavel,
Would you care to start the list of all the advantages?
ES
Old 2nd January 2013, 07:28 PM   #32145
PMA's Avatar
Much better rejection of interference voltages, you can easily measure it and compare to center-tapped bridge. You are capable enough to do it yourself, Ed. Ground contamination of center-tapped bridge is MUCH higher.
Old 2nd January 2013, 07:45 PM   #32146
You mean like this?
Old 2nd January 2013, 08:24 PM   #32147
Telstar is offline Telstar  Italy
Originally Posted by RNMarsh View Post
yes. My sediments, exactly :-)
Are you a stone, or you did mean sentiments, Ryan?
"The total harmonic distortion is not a measure of the degree of distastefulness to the listener and it is recommended that its use should be discontinued." D. Masa, 1938
Old 2nd January 2013, 08:26 PM   #32148
jcx is offline jcx  United States
being able to use the better performance positive linear regulators for both polarities is a handy split sec/dual bridge feature
but in a preamp avoiding most of the single bridge-CT common impedance noise isn't that hard with intelligent layout, routing, choice of gnd points - in power amps the currents are a little large for doing it right with just pcb trace - but still can be largely attenuated compared to naive implementations
but treating it as a pro level audio amp design secret when the issue is shown in Self, Cordell books is a little behind the times - either nih syndrome or once again propping up a strawman version of what "conventional enigeering" knows, even modestly well read interested audio amp designers should have seen
Old 2nd January 2013, 08:40 PM   #32149
john curl's Avatar
As we know:
1. It is impossible
2. It is possible but not important
3. We invented it. '-)
Old 2nd January 2013, 08:47 PM   #32150
who cares about ancient history, exact path to best practice, it all has to come form somewhere - and some local "audio" designers seem to be reluctant to credit EE as having more sophistication, many sub fields, think they don't have to look in any other specialty for design principles, insights
but now its in audio power amplifier design "textbooks", hard to deny that == "what conventional (audio) engineering knows"
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
