The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 26th December 2012, 11:29 PM   #31791
On Hiatus
SY's Avatar
Define "accurate mike."
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 26th December 2012, 11:37 PM   #31792
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by john curl View Post
That is when you first found out about microphone impedance? Congratulations.
A condenser microphone is a capacitor, what are you trying to say (1928 I was not around then)? What is the noise on a capacitor? Well let's see, one classic text book technique is to integrate the noise on a parallel R C network from 0 to infinity and as R goes to infinity the answer is always KT/C. Guess what the spectrum looks like? This is OLD stuff.
Or what's the current noise of a resistor? Sqrt(4KT/R) gee what does that mean?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 26th December 2012, 11:43 PM   #31793
Originally Posted by fas42 View Post
I'll bow to your greater experience ... !
But, this does remind me ... it's impossible to get sensible measurements about mic distortion anywhere; yes, I know there's a special technique using face to face mics to do the job (?), but no-one actually specifies anything worthwhile of the results.
Or do they ... ?
Frank
You are talking about reciprocity which only works on some mics. Google will turn up lots of results. This is the accepted lab standards way (as well as the electrostatic actuator method). There is an obvious technique using two tones one coming from each of two speakers so the IM is only from the mic. With care this can be very good.
Old 26th December 2012, 11:49 PM   #31794
Anybody yet figure out WHY B&K used such a low input Z?
They were making measurement insrtruments and it didn't matter. B&K technical journal 1972 recommends 10G Ohms BTW.
Old 26th December 2012, 11:51 PM   #31795
fas42 is offline fas42  Australia
Banned
Yes, but who publishes results? A couple of times I hunted around, but all I came across was single figure "nonsense" and the like. What about full spectrum, at different levels, you know, "engineering stuff" ...
Frank
Old 27th December 2012, 01:02 AM   #31796
john curl is offline john curl  United States
john curl's Avatar
No, they were worried about HUMIDITY! It is so good that you have known everything useful for just about forever, even before 1966. I didn't. I was still in the dark. I always try to credit my sources.
"Condemnation without Examination is Prejudice"
Old 27th December 2012, 01:04 AM   #31797
john curl's Avatar
In 1972, I was seeking out 100G resistors. Chickened out using them, settled for 1G and 10G. Still have some.
Old 27th December 2012, 01:05 AM   #31798
john curl's Avatar
Fas 42, it doesn't really matter. Start with a measurement mike and compare.
Old 27th December 2012, 01:11 AM   #31799
On Hiatus
SY's Avatar
Even in 1966, the ways to deal with that were known. Electrometers used very high value resistors.
Old 27th December 2012, 01:28 AM   #31800
john curl's Avatar
I did NOT create the B&K schematic that I had to upgrade. They did, AND they told me that this was the reason in 1973. Now for the resistors I still have left:
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
