The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 8th December 2012, 03:42 AM   #31091
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
You forgot cassette tape on your list.......
Old 8th December 2012, 03:43 AM   #31092
fas42 is offline fas42  Australia
Banned
Originally Posted by hitsware View Post
All of them exhibit usually undefined artefacts.
One of my best experiments:
Take any driver .......
In a quiet room lay it on the table in front
of you.
Drive it to just less than xmax @ ~ 10Hz
Listen carefully ..........
But ... have you tried doing that with the driver dead cold, and then compared that to the same unit after it's been installed in a carcase and driven hard for an hour or so with real music material, removed immediately and laid on the table again ...?
Frank
Old 8th December 2012, 03:46 AM   #31093
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Because I was only talking about decent sources Steven That one's neither decent nor technically decent.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 8th December 2012, 03:53 AM   #31094
I left off the smiley face, it was a joke......
Old 8th December 2012, 03:56 AM   #31095
abraxalito's Avatar
You could have faked a troll by interpreting 'tape' as 'cassette tape' rather as jcx interpreted my word 'decent'
Old 8th December 2012, 03:58 AM   #31096
kgrlee is offline kgrlee
Originally Posted by fas42 View Post
... one of the cheap speakers in my system actually suffers from this when cold, at one stage I was fooling around a bit with the MATT track for assessing speakers and this made it obvious. The interesting thing is that driving the speaker hard effectively "lubricates" the problem area, you can hear this distortion steadily disappearing as the suspension or whatever warms up.
Frank, if it's a small speaker, get a pack of Cotton Wool from the chemist and try wedging a lump behind the cone and the chassis. Try not to move the cone forward or backward.
It's not a permanent solution cos the Cotton Wool eventually falls off.
If you play a sine wave while pressing gently on the cone surround, you can work out which way you need to nudge the cone.
On a big speaker, turning the unit round often works. What happens is that heat/humidity allows the cone/coil assembly to creep and tilt.
I know all this cos that's how I get the computer speakers I rescued from the tip to work.
Old 8th December 2012, 04:02 AM   #31097
abraxalito's Avatar
Originally Posted by jcx View Post
both vinyl and tape have clearly audible defects in addition to the numbers
Not disputing that for a moment. Current digital implementations have clearly audible defects IME too even though standardized numbers don't as yet exist for them. But I have no doubt they'll come in due course.
Old 8th December 2012, 04:11 AM   #31098
Originally Posted by abraxalito View Post
Don't you have to pick a decent source first? What's it to be - vinyl, tape or DAC or all of the above?
One of the most important facets of the test is that the subject picks the music and the source.
If JC, was doing the test, he uses his own CDs, vinyl, SACD etc. And he MUST be happy with the player; .. not a problem if the test is conducted at chez Curl.
But if his nominated golden pinnae wants cassettes, presumably this august person has a good cassette player he could lend us. Alas, all of mine are dead even if the termites haven't eaten them.
Indeed - the first error they make is calling it, and treating it as, a 'test' when listening is purely for pleasure.
Abra, this is another important facet; that the subject 'enjoy' at least one presentation.
We ensure this by letting the subject listen to his preferred system while he can see what it is first so he is happy it is functioning correctly.
There is no doubt in my mind that Blind Tests are stressful. IMHO, this is the MOST important criticism of most Blind Tests. I spent nearly 2 decades working on this problem with some success.
It's only when you manage this that you have any chance of finding the true golden pinnae. If you are lucky enough to find them, be prepared to be amazed at what some people can pick out.
Old 8th December 2012, 04:13 AM   #31099
abraxalito's Avatar
OK, sounds a tad more promising than the usual tests I guess that could be because you're not (as in the case normally) expecting a null result?
Old 8th December 2012, 04:36 AM   #31100
Is anyone seriously interested in yet another NULL test result? At best, it would rate a single line in a Stereophile editorial. Certainly not worth an AES paper from the Dynamic Duo.
But if some people can reliably distinguish between Blowtorch and an evil 4558 device, this would be NEWS. It would answer Jay's Question 1.
Only if the answer to this is YES, can we answer his Question 2 Which one sounds better?
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
