The Lounge A place to talk about almost anything but politics and religion.
Old 14th November 2009, 04:53 PM   #2861
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by ikoflexer View Post
Interesting; I'm thinking out loud here... with the buffer at the load, 2cm length of 1mm diameter wire amounts to about 14nH inductance, which, can be significant. Theoretically one should be better off with remote sensing, unless I'm missing something again?
Do you mean remote sensing phase shifts?
The Devil is not so terrible as his math model is!
Old 14th November 2009, 05:05 PM   #2862
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Hmmm. Not sure I get your point. My idea was to get the output stage (buffer) just a few mm from the load circuit. So the inductance of the load carrying wire is negligleable. The remote sense still has higher inductance but since that circuit is higher impedance the impact of the L is relatively lower. What do you think?
Edit: in my idea, the sense would still go back sveral inches to the control circuit (error amp, ref etc).
jd
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 14th November 2009, 05:06 PM   #2863
iko is offline iko  Canada
iko's Avatar
How bad can it be?
Old 14th November 2009, 05:11 PM   #2864
jan.didden's Avatar
Originally Posted by john curl View Post
Actually the expert you are referring to, was just brought up, yesterday in fact, as one of the most 'clueless' of the group, here, by one of my references. I did not 'lead' the conversation, my source has read his papers.
I said expertS. And you don't know which I meant. I meant those people who have for the past several years not only given their position but backed it up with experiments and measurements. You and your 'references' have limited themselves to explaining when they had lunch together and what car they drive. Some references.
jd
Old 14th November 2009, 05:17 PM   #2865
john curl is offline john curl  United States
john curl's Avatar
Quote without comment:'4.2.5 Interelectrode Parasitic Capacitances'
"Capacitance is a dynamic characteristic, as it is measured at a high frequency, generally 1MHz. For any FET, whether it is a SIT or a power MOSFET, we collect the various parasitic capacitances and identify them as Ciss, Coss, and Crss.
Each of these capacitances are complex, consisting of numerous parasitic elements. Furthermore, these capacitances are voltage-dependent, raising to high values at low voltages and frequently decaying to quite low values at high voltages. ... etc., etc."
Ref: Ed Oxner, one of my mentors.
"Condemnation without Examination is Prejudice"
Old 14th November 2009, 05:22 PM   #2866
john curl's Avatar
Jan, you are not being helpful, and if I try to 'help' you, you just sit on your duff and criticize my input, and indirectly the input of those who teach me. Why should they come here and waste their time debating what they have found important in audio over the last 50 years?
Old 14th November 2009, 05:26 PM   #2867
john curl's Avatar
OK, first, would you like to debate Ed Oxner on the non-linearity of MOS or SIT input stages? This is the first stage in understanding the source of FM distortion in audio equipment.
Old 14th November 2009, 05:31 PM   #2868
iko's Avatar
jd
In my experiments the inductance and resistance of the remote sense leads had almost no significant effect (tested with about 15cm length), whereas a few cm of directly connected wire did have. This I tested in a real shunt reg with a sine wave load of about 56kHz. Before testing it for real I simulated the parasitic properties of the wire, somewhat exaggerated too, and the results were very good. Please don't be offended, I mention this for other beginners like me, who will benefit: it is essential to measure the voltage differentially at the load, V_positive-V_negative, and not V_positive - GND. I used the diff amp channel A-B on my ancient oscilloscope, at the 100uV/div, with probe A connected to V_positive and probe B connected to V_negative, and their grounds to the regulator ground.
Old 14th November 2009, 05:45 PM   #2869
Magura is offline Magura  Denmark
Magura's Avatar
Now, I see where you get your idea, however, you are still off, theoretically. Do you know what the transfer equation is for a V fet, or Static Induction Transistor (SIT)?
IDS = IDSS [1 (VGS / VP)]2
Magura
Everything is possible....to do the impossible just takes a little while longer.
www.class-a-labs.com
Old 14th November 2009, 05:50 PM   #2870
jan.didden's Avatar
I was reacting to your post implying that feedback causes TIM, PIM, whatever as a blanket statement. Does Ed Oxner write somewhere that this is the case? Show us, if not, please stop trying to mislead us that the above has anything to do with that issue.
jd
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
