The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 27th October 2012, 12:12 AM   #28501
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Actually in a way that phase modulation is quite easy to measure for all of us:
Measure the phase shift between input and output with zero Vout.
Then insert a DC offset of a few volts, and again measure it; you'll find it most probably has changed.
One typical table from his paper:
DC offset at the output Phase shift @ 15kHz
-2V -25 degr
-1V -24 degr
0V -23 degr
+1V -22 degr
+2V -21 degr
So there's you varying phase shift with output level.
Fascinating, isn't it?
jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 27th October 2012, 12:21 AM   #28502
On Hiatus
SY's Avatar
How do you accomplish that at zero volts out?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th October 2012, 12:22 AM   #28503
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Nothing is new under the sun. ( King Salomon )
Old 27th October 2012, 12:39 AM   #28504
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Jan;
I can tel you the similar way to catch a mice. When it is under the stool take a saw and quickly cut stool's legs.
1. Cut the 1'st leg 0.5 centimeters
2. Cut the 2'nd leg 0.5 centimeters
5. Go to 1 and repeat until the space is too small for the mice to escape.
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 27th October 2012, 12:44 AM   #28505
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
-2V -25 degr
-1V -24 degr
0V -23 degr
+1V -22 degr
+2V -21 degr
So there's your varying phase shift with output level.
jan
Facinating! OMG. Maybe what M.Otala and JC etal has been talking about is true? And, what would that affect do to the clarity of the sound?
I wouldn't be surprised to find that this affect has also been heard and described by careful listeners without knowing what it was, exactly. And, why certain designs sound better and thus contributes to why JC does design the way he does? OMG.
Old 27th October 2012, 12:50 AM   #28506
Wavebourn's Avatar
What is fascinating?
Did you hear SSB station on AM radio? How does it sound?
Similarly, very small amount of phase intermodulation causes "harsh" highs and fuzzed stereo image. It's one of reasons why measurements of THD and IMD don't tell how good will be the sound.
Old 27th October 2012, 12:51 AM   #28507
kevinkr's Avatar
Phase shift is referred to changing levels of DC offset at the output. (Not changing levels of AC signal amplitude) This apparently is pretty typical behavior for op-amps operating on relatively low supply voltages, shifts internal operating points, etc. (Look at GBWP and phase margin at different supply voltages for a hint)
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 27th October 2012, 12:57 AM   #28508
jan.didden's Avatar
Zero V DC. You need to have a small signal riding on the DC offset to be able to measure the phase shift.
Of course.
jan
Old 27th October 2012, 01:00 AM   #28509
jan.didden's Avatar
Originally Posted by kevinkr View Post
Phase shift is referred to changing levels of DC offset at the output. (Not changing levels of AC signal amplitude) This apparently is pretty typical behavior for op-amps operating on relatively low supply voltages, shifts internal operating points, etc. (Look at GBP at different supply voltages)
Except that the opamps all measured essentially the measurement floor. Even the lowly TL074. Low ol bandwidth, very high feedback factor, go figure.
jan
Old 27th October 2012, 01:01 AM   #28510
jan.didden's Avatar
Ohh yes of course it is true.
But not where we thought it was.
jan
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
