The Lounge A place to talk about almost anything but politics and religion.
Old 24th October 2012, 08:27 PM   #28421
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by PMA View Post
Transformation of acoustical impedance. Distortion is on behalf of the driver.
Do you mean on behalf of non-linear compression of the air in the transformer?
The Devil is not so terrible as his math model is!
Old 24th October 2012, 08:33 PM   #28422
Wavebourn's Avatar
Here is a tweeter in the center channel of my HT. It consists of 64 capsules, 12 mm diameter. Can I get distortions similar to horn throat distortions? No way.
Old 24th October 2012, 09:25 PM   #28423
Esperado is offline Esperado  France
Banned
Originally Posted by john curl View Post
... Distortion...proportional... to the square root of the sound intensity.
No comments.
But that can explain why John is so upset, measuring PA systems for Big halls with horns distortions. And why i prefer horns for home.
Old 24th October 2012, 10:03 PM   #28424
john curl is offline john curl  United States
john curl's Avatar
Well, of course, Esperado. I first reacted to your 'horns and 10KW' PA that you apparently ran for a time, NOT your home system. The GD system was modified to remove many of the midrange horns BECAUSE of horn throat distortion in the original multi-midrange horn setup used for at least 4 years previously. Have you learned anything new, yet?
For the record, what was the PA system that you ran with '10KW and horns' consist of? Then let us talk.
"Condemnation without Examination is Prejudice"
Old 24th October 2012, 11:44 PM   #28425
Banned
"For the record", all JBLs, near everything in their catalog. You know, those very bad horns, plenty of them and bass cabinets...Castles at the side of the scenes...
Absolutely awfull regarding any form of fidelity. But no larsen, very dynamic and impressive for drums, such a directivity that it was possible to project sounds to hundreds of meters, able to keep intelligibility even is some catastrophic hall's reverberations and, once equalized, some guys in the public where even able to recognize instruments :-)
You know... PA !
I remember, if you shouted a " bow" in the mike, with some delay, it was like a plane in your face in return from the back of the hall...
At this time,if you spoke to me of some horns in my home system, I would have killed you.
If i had learned something ? About PA ? Not really.
About Home; Yes.
That * Good horns * can change everything. When i say good horns, i do not include metallic ones, constant directivity ones, or traditional expansion curves (cone, hyperbolic, , parabolic).
... That the horn expansion curve has to be carefully calculated in correlation with the specific drive you use (how spherical is the wave's form, angle of the throat etc...)
That your horn has to present the same surface at the crossover frequency than your bass speaker or, at least, the same directivity curve...
That it is good to calculate-it for one octave under the cross over frequency...
That it is very difficult and time consuming to tune the filter's levels for a perfect coherency...
Once done, i do not know a more natural and dynamic reproduction than the one that offer a two way system with such a horn with a good driver (not easy to find neither).
Old 25th October 2012, 12:23 AM   #28426
john curl's Avatar
Well, at least you didn't much of your own PA either. '-)
Old 25th October 2012, 12:28 AM   #28427
Pano is offline Pano  United States
Pano's Avatar
Is there a word missing above?
Old 25th October 2012, 12:50 AM   #28428
Kindhornman is offline Kindhornman  United States
Kindhornman's Avatar
Think I would imagine.....
Old 25th October 2012, 12:57 AM   #28429
fas42 is offline fas42  Australia
Banned
There are so many dimensions to "good" sound, and when two people listen to the same sound different priorities are placed on various aspects. I look for naturalness, others for absolute correctness of some tonal characteristic, there are myriads of permutations ...
Frank
Old 25th October 2012, 01:02 AM   #28430
Frank,
I would say that natural and sonically correct are one in the same in my book. To me it can not sound correct if it doesn't sound natural or at least reproduce what was intended. What I don't like is harsh, bright, muddy, smeared or any of those things as that is what I would think of as unnatural.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
