The Lounge A place to talk about almost anything but politics and religion.
Old 16th October 2012, 08:12 PM   #28201
john curl is offline john curl  United States
john curl's Avatar
Back in 1975-6, I designed circuits for him. We went to Paris together from Montreux, Suisse to Paris in his Porsche 356. (Hard on the ears and the body!) to work at a studio.
"Condemnation without Examination is Prejudice"
Old 16th October 2012, 08:24 PM   #28202
Esperado is offline Esperado  France
Banned
Originally Posted by PMA View Post
Very fast bipolar CFA designed for high PSRR at high frequencies may sound great, I agree. Tough competition to JFET miracles
on the pit lane with very fast (HEX/MOS)FET CFA designed for high PSRR at high frequencies...
Ultra compact and nice resuming, PMA.
Old 17th October 2012, 01:08 AM   #28203
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
Thumbs up CFA
CFA
Old 17th October 2012, 06:49 AM   #28204
staccatiss is offline staccatiss  Germany
My dilemma with servos are what caps to use in them? Are they contributing as much colouration as a series DC blocking cap? I often use 220n - 2u2 PP caps for my servos but to make these caps a "super" cap, cost a small fortune and takes up huse amounts of PCB space....
/S
Originally Posted by john curl View Post
If you want the 'hand carved by virgins' sound, I should think that you must go to the Mundorf or similar cap. In fact, in a project that I am associated with, the first cap, a typical mylar, was changed to Rel, with great subjective improvement, then 'Mundorf with even a further subjective improvement. I recommended a SERVO to remove the cap completely.
Old 17th October 2012, 01:09 PM   #28205
Banned
If you use a Fet Op. Amp, the inverting input impedance is so high that you really don"t care about any inductance or resistance of the cap.
The cap can have only an influence at frequencies lower than the cutting frequency of the low pass filter.
Means far away from the audio range, as you can set this frequency very low.
Because the high impedance, you can use any polypro film cap, and concentrate on the quality of the op amp: Low noise, low drift and offset; unity gain stable.
Old 17th October 2012, 01:17 PM   #28206
Banned
Not to mention that, with a good design, paired and thermally coupled parts, you can design an amp with a drift and offset low enough that you can forget about-it.
And a clever protection circuit can protect-it against DC in the input, as well he can protect your speaker from amp failure.
I do not have any serial cap in all my home system.
Old 17th October 2012, 01:34 PM   #28207
john curl's Avatar
Are you going to share your circuit 'secrets' with us, Esperado? '-)
On my part, I usually use a quality mylar cap for the servo, BUT I do make sure that the servo is operating well below the audio bandwidth. Servos become subjectively problematic if care is not taken to decouple them and to keep the bandwidth very low. Still, I am often reminded that better caps make better servos. It is most likely true.
Old 17th October 2012, 02:40 PM   #28208
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
Has anyone tried thermal feedback?
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 17th October 2012, 03:15 PM   #28209
Bob Cordell is offline Bob Cordell  United States
Hi John,
See Section 8.4 on page 167 in my book for a description of using the DC servo integrator output for detecting DC offset for protection. See also page 335 under Loudspeaker Protection Circuits.
Bob
Old 17th October 2012, 03:16 PM   #28210
john curl's Avatar
Good idea, Scott. Why don't you show us an example of how to do it?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
