The Lounge A place to talk about almost anything but politics and religion.
Old 2nd October 2012, 08:53 PM   #27941
john curl is offline john curl  United States
john curl's Avatar
SY, I design for low distortion, BUT not with heroic amounts of negative feedback to get me there. I am suspicious of global negative feedback, especially when it tends to lower the open loop response. I ALWAYS look out for odd order harmonics, but below -110 dB, then perhaps they are not so important.
There is more to audio sound quality that steady state distortion. That is my opinion and experience.
For balance, the Halcro preamp got a bad review in 'Hi Fi News' years ago. Something about the digital power supply effecting the rest of the equipment in a bad way.
"Condemnation without Examination is Prejudice"
Old 2nd October 2012, 09:10 PM   #27942
On Hiatus
SY's Avatar
And for all your suspicion, here's one that has superb measurements and won the "listening contest."
After getting data contrary to a hypothesis, some might conclude that the hypothesis is flawed.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 2nd October 2012, 11:33 PM   #27943
Moderation Team is offline Moderation Team
Moderation Team's Avatar
OT posts removed.
Old 3rd October 2012, 12:05 AM   #27944
fas42 is offline fas42  Australia
Banned
Originally Posted by john curl View Post
'High end' for me is the effort to eliminate higher order distortions that can give listening fatigue, as well as to attempt to effect a 'you are there' at least for a moment experience with a lot of musical sources. For this, often 'inner details' in the music become apparent, and this can help to make it more realistic sounding. You know, when the applause actually sounds like hands clapping, rather than some sort of 'mush', or you get 'goosebumps' from the performance.
Exactly. Unfortunately, this is in the "devil's in the details" area, in my experience. When I get to this point the slightest variation from optimum causes the subjective quality to plummet, it's a very fine balancing act. One of the reasons is that when the SQ is spot on then you can wind up the volume as far as you like with no problems, this is in the territory of being able to go outside the house and the music inside still sounds completely realistic. But, at these volumes the slightest audible deficiency sounds horrendous, it is instantly unlistenable to ...
Very much, razor's edge territory ...
Frank
Old 3rd October 2012, 12:08 AM   #27945
RNMarsh is offline RNMarsh  United States
RNMarsh's Avatar
A hypoth that a super low THD+N in a power amp listening contest would NOt mean that only THD+N was the reason for a win. Or, sole reason. PSRR, PS noise, regulation of the PS under those load conditions, CMRR, peak current into various load Z, output Z et al are needed to get an over-all evaluation of the total parameters that lead to the decision. AND, how the total harmonic structure combined in That system being used in the listening test. -RNM
Old 3rd October 2012, 12:20 AM   #27946
On Hiatus
SY's Avatar
Perhaps all that ties into the (according to John) super high levels of "global" feedback. The THD performance is just part of the picture, the result of excellent engineering, not a specific desideratum in and of itself. It performs well because the designer knew what he was doing and didn't reflexively dismiss using good engineering practice because of being stuck in 1968 thinking.
The "listening contest" performance has very little- or perhaps nothing- to do with actual listening, but clearly the designer knew how to make something that looks and feels impressive as well.
Old 3rd October 2012, 01:18 AM   #27947
Banned
Also known as, everything matters. Such a glib thing to say, rolls off the tongue so easily ...
And also practically universally ignored ...
Frank
Old 3rd October 2012, 01:55 AM   #27948
john curl's Avatar
SY, I designed a line driver for Sound Technology in the 1980's that had about -100dB of distortion at 100KHz. Much less than that below 100KHz. I just do not use that design approach for audio listening, just instrumentation.
Old 3rd October 2012, 06:44 AM   #27949
john curl's Avatar
Everything matters, fas42! That's how it gets made right. '-)
Old 3rd October 2012, 07:50 AM   #27950
sofaspud is offline sofaspud  United States
sofaspud's Avatar
I think I already know the answer, but just to be sure...
Because for listening, that approach just doesn't end up sounding right?
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
