John Curl's Blowtorch preamplifier part II John Curl's Blowtorch preamplifier part II - Page 2688 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 23rd August 2012, 01:57 PM   #26871
On Hiatus
SY's Avatar
Vague and poorly worded question, easy to do with a couple of symmetry assumptions (Laplace will work, there's easier ways) once that was teased out of Ed, no real motivation. Time waster if the point of the "exercise" isn't given and the goalposts are likely to be moved.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 23rd August 2012, 01:58 PM   #26872
PMA is offline PMA  Europe
PMA's Avatar
Well John, I am 57 and might be considered rusty as well. But, my everyday experience dictates me to be able to learn continuously (hw, sw, cad etc.) and not to forget basics. Forgetting basics means one is unable to assess technical/engineering issues properly.
Old 23rd August 2012, 02:13 PM   #26873
simon7000 is offline simon7000  United States
Brad,
Have you ever had any engineering use for the average value of a half sine?
Old 23rd August 2012, 02:20 PM   #26874
bcarso is offline bcarso  United States
diyAudio Member RIP
Originally Posted by simon7000 View Post
Brad,
Can't recall that I have Ed. Perhaps tomorrow
Old 23rd August 2012, 02:27 PM   #26875
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Brad,
Yes, the mean average deviation portion of computing amplifier efficency by class A/B, H, G etc. It's contained as an appendix in my class H ADSL driver paper (ISSCC). It has been referenced in several text books since.
PMA - some of us just don't want to play.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 23rd August 2012, 02:29 PM   #26876
Back to the problem.
Pavel showed a nice simulation and answer that the power dissipation is the same in both resistors. Now for some that doesn't seem reasonable as one is in series with a capacitor and the other is directly across the power source.
So lets look at what happens. As the current starts from zero and rises to one amp the capacitor charges and the voltage across the capacitor rises. This drops the voltage across R2 but since we have a current source the voltage rises across R1.
When the current source goes from 1 amp to -1 amp there is still a charge on the capacitor and this must discharge through R2 so the initial surge current is a bit greater than from just the current source. As the capacitor charges in the other direction we again see more energy into R1.
Now the next issue was can the circuit be simplified? The answer is to treat the current source and R1 as a Thevenin equivalent.
The attached image shows what happens.
For those who don't understand the transform, compare the open circuit voltage and the short circuit current, they remain the same. So the two circuits are equivalents and make it clear that the power in R1 must equal that of R2.
Now that we have discussed power in an RC circuit and reduced the problem to one, What happens if we calculate the power in R2 by using a Fourier series to represent the square wave voltage source?
Old 23rd August 2012, 02:36 PM   #26877
Wow Scott,
That makes sense on both counts.
SY,
A big part of engineering is defining the problem. If you found it confusing you just could have asked.
Pavel,
I am afraid I will want to do vectors and the unit circle bit as some here don't seem to know it. But I will keep it to one post. You can take a nap then!
Dave,
I actually expected someone to give the answer of 10 watts as capacitors do not dissipate power. But most of the PM'd answers were 2.5 watts! (And I will not admit to having made the same mistake myself once or twice!)
ES
Old 23rd August 2012, 02:37 PM   #26878
diyAudio Member RIP
Scott, is there a downloadable version?
Old 23rd August 2012, 02:37 PM   #26879
On Hiatus
SY's Avatar
I found it vague and pointless. Your most recent "problem" even more so: "Solve this using an inappropriate tool."
Old 23rd August 2012, 03:46 PM   #26880
SY,
The use of loop equations is the first step in analyzing any circuit. Although on a very simple circuit many can isolate the issue and use an easier method of solution, but then when confronted with a large complex circuit having the skills to dissect it and solve it are needed.
Now today most folks will use a simulation program that figures out the loops and does the calculations automatically.
But I think most of us even here recognize understanding how the simulation works even if we could not do the entire job by ourselves is a great benefit.
Now the questions were dead bang simple and what you get out of the answers is for some a refresher, for others a new experience and for some it casts new light on old problems.
You certainly don't have to pay any attention to it. However as you chide John for not doing double blind tests, I reserve the right to chide you for not even attempting the simplest question.
I picked that one because I figured almost every one knows that when the reactance equals the resistance that is the half power point.
ES
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
