The Lounge A place to talk about almost anything but politics and religion.
Old 31st May 2012, 06:06 AM   #23581
1audio is offline 1audio  United States
Originally Posted by Wavebourn View Post
Which Medical version do you mean? I have not seen filters without that Y-caps, so I never used them.
Read the datasheet. The B version is without Y caps. The medical leakage requirements are in line with good audio. . .
Demian Martin
Product Design Services
Old 31st May 2012, 06:50 AM   #23582
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Thanks!
The Devil is not so terrible as his math model is!
Old 31st May 2012, 03:00 PM   #23583
simon7000 is offline simon7000  United States
I prefer power transformers with internal shields between primaries and secondaries.
And just what do you do with this shield? I take it you mean an insulated conductive foil (so as not to act as a shorted turn) with a drain lead attached.
The first issue is to identify on the primary which lead goes to the inside of the coil and be sure that is connected to the neutral. (The neutral is actually grounded in the U.S.) This means that you have minimum coupling of the AC line directly to the metal of the transformer core and through it's mounting into your chassis.
Now when you have a transformer where the secondary is wound on top of the primary you will have the "Hot" lead coupling better into the secondary! Placing a shield here is the old method of reducing the issue. However if you connect the shield to the common or ground then you are coupling the noise into your circuit. If you connect the shield to the safety ground wire, then you have to float the chassis or ground. But any noise or RFI that comes in on the ground line will have greater coupling into the secondary. So you basically are trading hum for RFI!
If you connect the shield to the neutral you violate code and will have real fireworks if it ever gets plugged into a incorrectly wired outlet.
Now with a split bobbin you have a bit of capacitance from primary to secondary. However as the dual secondary is wound at the same time you get a differential mode that cancels much of the coupled noise!
Old 31st May 2012, 04:27 PM   #23584
Wavebourn's Avatar
Hi Ed;
connecting something means creating path for current. All depends on which path, and is this path common also for small signals, and how big is voltage drop created by this current in respect to signal voltage. And how they are coupled by fields. Search for your optimum. I search for mine.
Anatoliy
Old 31st May 2012, 04:35 PM   #23585
john curl is offline john curl  United States
john curl's Avatar
Well said, Ed Simon. Where, oh where, do we connect the shield wire? A fundamental and often 'fatal' question.
Bonsai, we normally use more 'modern' transformers, today, especially when the transformer is located near the audio electronics. In the CTC Blowtorch case, we designed the power supply chassis to be located away from the audio, so we could use these more traditional transformers, especially designed to be low capacitance between the input and output windings. Parasound preamps use a R core (I'm pretty sure) that works pretty well, and has less stray field.
"Condemnation without Examination is Prejudice"
Old 31st May 2012, 05:55 PM   #23586
PMA is offline PMA  Europe
PMA's Avatar
Test and measure, guys. Words tend to be empty
Old 31st May 2012, 06:04 PM   #23587
Wavebourn's Avatar
I prefer to add "Think" to this loop.
Old 31st May 2012, 06:32 PM   #23588
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
Scott's magic finger?
Or otherwise, it's a thing I suggested before: why not have one safety ground also used for shielding, and a separate floating signal ground? Following Class II requirements for the innards, there should not be any safety issues.
Wouldn't work with RCA cables, but XLR with one hot and one signal earth wire would. No pin 1 problem possible, since signal earth and shielding earth have no connection.
vac
First in distortion-free self-amplification.
Old 31st May 2012, 06:36 PM   #23589
Wavebourn's Avatar
With XLR I don't need even to think about anything floating except balanced signal wires.
Old 31st May 2012, 06:48 PM   #23590
john curl's Avatar
I prefer to add LISTEN to this group. '-)
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
