The Lounge A place to talk about almost anything but politics and religion.
Old 30th May 2012, 11:18 AM   #23501
wahab is offline wahab  Algeria
Originally Posted by Wavebourn View Post
All outputs of all supplies are connected together in one point that is the ground.
This point exact physical position is defined only at iddle
or eventualy in a schematic...
Once the system is in large current mode the said point will be
a moving target.
Old 30th May 2012, 02:28 PM   #23502
jneutron is offline jneutron  United States
jneutron's Avatar
I have a scope. And when I short tip of the probe with it's ground crocodile near any wire that charges caps through diodes I see spikes.
You are measuring dB/dt, a consequence of amperes law and faradays law. This effect is why star grounds do not work with low impedance circuitry. Bonzai is very knowledgeable on this aspect, IIRC he drew a 4 wire capacitor on a simple supply schematic..
Originally Posted by Chris Hornbeck View Post
If a center tapped transformer is used to establish the center point of a dual polarity power supply, any imbalances, including AC ones, appear as current into the "ground". In a circuit with a single true star ground and no ground loops this is no problemo, but what real circuit has no ground loops?
That is incorrect (in red).
The real problem is this: how does one approach a designated zero potential reference point through a path in 3 dimensional space which has time varying magnetic fields... without inducing differential voltages between two wires ala faradays law of induction?
Simple.
1. via two paths which do not trap time varying magnetic fields.
or
2. via two paths with identical integrated time varying magnetic fields.
For #1, geometry of 3-d space states that there can only be 3 paths which are magnetically orthogonal, so practical circuit design cannot use this. There are some simple ways around this.
For #2, it is almost impossible to do this, and the only practical methods to do this are extremely counterintuitive.
The most important thing here is: star grounds are high impedance constructs. NOT for low impedance with high current slew rates.
ps...btw, this is standard stuff....and works for uV level instrumentation wires buried in 10 tesla magnets running 13 kiloamps, up to 45 kiloamp primary/15 million amp secondary structures over ten meters tall.
j
Old 30th May 2012, 03:23 PM   #23503
Bonsai is offline Bonsai  Europe
. . . winding temperature measurement with an RTD perhaps?
Old 30th May 2012, 03:48 PM   #23504
jneutron's Avatar
Milli-kelvin accuracy temperature measurement at 1.8 Kelvin using ceramic-oxy-nitride.
1 part in 10e6 magnetic field measurements in 5 to 10 tesla superconducting magnets.
Quench detection of the 30 gigajoule ITER solenoid during plasma initiation.
As well as some difficult tasks...
j
Old 30th May 2012, 04:18 PM   #23505
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
a moving target.
Moving in respect to what?
The Devil is not so terrible as his math model is!
Old 30th May 2012, 04:21 PM   #23506
jneutron's Avatar
Detroit.
j
Old 30th May 2012, 04:22 PM   #23507
Wavebourn's Avatar
Absolutely right. I always solder 4-wire capacitors on breadboards and in prototypes.
Old 30th May 2012, 04:32 PM   #23508
jneutron's Avatar
When using a 4 wire capacitor, use a braid to carry the current from one end of the capacitor over it's body. This negates the external magnetic field caused by the physical length of the capacitor. No, it cannot negate the solenoidal field of the internal foil wrap if the manu kept them apart. But the selection of a low ESL will take care of that.
Using the braid option eliminates the mutual inductance.
This technique works on diodes and resistors as well.
j
Old 30th May 2012, 04:46 PM   #23509
Wavebourn's Avatar
I once even wanted to buy a loom machine to manufacture high-end resistors, including non-inductive multitap carpets for volume controls.
Old 30th May 2012, 05:00 PM   #23510
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
j
Braid sounds like great idea. However, wouldn't it go some way already to mount axial stuff vertically with the return lead close to the body? Or, what I have been doing in the PS I am working on, take two resistors of 1/2 the desired value, connect them at the top and mount the two which are now in series vertically on the PCB. This will also keep the junctions balanced and as closely as possible at the same temperature. I just surmised this would be better, but the differences are below what I can measure, so who knows?
vac
But from now on I will be discrete about it.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
