John Curl's Blowtorch preamplifier part II John Curl's Blowtorch preamplifier part II - Page 2350 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 30th May 2012, 03:41 AM   #23491
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by Steve Eddy View Post
What about currents flowing into your reservoir caps? Is everything that comes after the transformer secondary going to be perfectly symmetrical?
I think we're getting at *why* this complication is used pretty well considering no drawing is in use. Well, there was a good drawing earlier.
The reason John Curl suggested thinking of batteries is that they float, and it's the floating that matters. Imagine a really messy noisy rectifier and cap followed by an appropriate filter. If this messy noisy power supply is truly floating no current will flow through its output terminals except that drawn by its load.
And what else floats? "A duck!" "Very small rocks?" "A witch!"
If power supplies are arranged so that *only* load current flows from its output terminals and she weighs the same as a duck, then she must be a witch.
Thanks,
Chris
Old 30th May 2012, 03:53 AM   #23492
Wavebourn is offline Wavebourn  United States
Wavebourn's Avatar
In John's case it is a little bit more complicated. I usually have transformer, rectifiers, and stabilizers, in the same box that they power, even when they are in different compartments shielded from each other. John had relatively long wires from power supply to the preamp. According to US regulations safety ground has to be connected to chassis directly near power socket, so such simple star ground approach that I use is impossible.
However, there are always many ways to skin the cat, so John used his own one.
The Devil is not so terrible as his math model is!
Old 30th May 2012, 04:12 AM   #23493
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Originally Posted by john curl View Post
No Johnferrier, it just showed how 'flawed' the double-blind test was. Carver is still making vacuum tube power amps. Why? Is he really that corrupt? '-)
You don't think he switched to performance art ?
Bob Carver's 900 watt monoblock amps on Ebay
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 30th May 2012, 04:21 AM   #23494
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
That's another 'secret' SE. Of course, you or SY will not think much of it, so I think I will leave it off the list.
Then you shouldn't have mentioned it at all.
se
The Audio Guild
Old 30th May 2012, 04:24 AM   #23495
Steve Eddy's Avatar
Originally Posted by hitsware View Post
........... I've been swamped before ........
I've always said you're all wet.
se
The Audio Guild
Old 30th May 2012, 04:29 AM   #23496
hitsware is offline hitsware
Highly damped
Old 30th May 2012, 04:37 AM   #23497
Steve Eddy's Avatar
You can create a "center tap" with batteries just as you can with transformer windings. So telling someone to think about batteries doesn't inform them as regards "floating" any more than telling someone to think about transformers does.
Only if everything is perfectly symmetrical.
So as I asked previously, is everything after the transformer secondary perfectly symmetrical?
se
The Audio Guild
Old 30th May 2012, 04:38 AM   #23498
Bonsai is offline Bonsai  Europe
Bonsai's Avatar
If a center tapped transformer is used to establish the center point of a dual polarity power supply, any imbalances, including AC ones, appear as current into the "ground". In a circuit with a single true star ground and no ground loops this is no problemo, but what real circuit has no ground loops?
Real circuits have two (at least) channels with their own signal grounds running off doing Lord knows what and having various other impure thoughts. Dirty current injected into an imperfect "ground" is only allowable without penalty with a ground loop free construction, a rare thing, usually requiring balancing or transformers. The dirty current injection is minimized by floating power sources up from ground until the last possible moment, then dropping 'em gently where they wanted to be all along. Isolation, then redemption.
Thanks,
Chris
Thats why you need to rectify, smooth and regulate the split secondaries first and combine them after that. Only signal return currents will then flow in the non-power ground, and if you bias everything up into class A (we are talking pre-amps here) only DC will flow in the supply rails - no signal related harmonics and wide band hash. Localized decoupling and filtering (no shunt regs please!) will further improve the overall noise performance.
Single secondary 'flipper' designs that generate a split rail suffer from more ripple and higher charging currents. And single rail, FWB rectified, smoothed and then split using a buffer to create a ground also have major compromises - especially so since the splitter is effectively in series with the signal.
You get nothing without paying for it somewhere along the line.
bonsai
https://www.ovationhifidelity.com/ and DIY here http://hifisonix.com/
Old 30th May 2012, 04:43 AM   #23499
Bonsai's Avatar
Originally Posted by vacuphile View Post
That is also how I see things, with the exception that I don't put snubbers across each rectifier, but small CLC's after them. Is there anything to say in favour of using the center tap as ground and saving 4 diodes?
vac
No
bonsai
Old 30th May 2012, 09:53 AM   #23500
Bonsai's Avatar
" . . . especially so since the splitter is effectively in series with the signal. "
ok - slight exageration - its the ground splitter circuit noise that appears in series with the supply rails, not the input signal. Still totally suboptimal in my book
bonsai
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
