The Lounge A place to talk about almost anything but politics and religion.
Old 30th May 2012, 01:48 AM   #23481
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by Wavebourn View Post
In which ground, Chris? In my power supplies "ground" starts from where all outputs of all voltage regulators I use are connected in single fat point. It is the ground. What happens on wires before this ground is obvious, but it is not reflected on output of PS, nor on any other "ground" that is connected to this point.
Can't edit, unfortunately. In my current "Nirvana" project I use +6.3V, -120V, +240V, and +420V. All outputs of all supplies are connected together in one point that is the ground. The same approach I use in all my designs, so I do not care what waveform of currents flow to rectifier, from rectifier, through any of it's wires, since they anyway float in respect to the ground.
The Devil is not so terrible as his math model is!
Old 30th May 2012, 01:59 AM   #23482
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Originally Posted by scott wurcer View Post
Nothing goes on that could be called a competition, it has been decades of performance art.
Didn't the competition end in '85 with the Carver Challenge ?
"Is it possible to make a $700 'mainstream-audio' power amplifier sound exactly like a high-priced perfectionist amplifier? Bob Carver, of Carver Corporation, seemed to think he could, so we challenged him to prove it. "
"The Final Achievement . . . This time, the listening went on through the whole afternoon and much of the evening, until all of us were listened out. More leisurely listening, refreshed by a good night's sleep, failed to turn up anything. As far as we could determine, through careful comparisons and nit-picking criticisms, the two amplifiers were, in fact, sonically identical. It is a gross understatement to say that we were flabbergasted! "
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 30th May 2012, 02:08 AM   #23483
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by hitsware View Post
Me too ( 24V wallwart ) ......
Careful. Those wallwarts will give you frogs.
se
The Audio Guild
Old 30th May 2012, 02:09 AM   #23484
john curl is offline john curl  United States
john curl's Avatar
No Johnferrier, it just showed how 'flawed' the double-blind test was. Carver is still making vacuum tube power amps. Why? Is he really that corrupt? '-)
"Condemnation without Examination is Prejudice"
Old 30th May 2012, 02:13 AM   #23485
On Hiatus
SY's Avatar
Well, some of us trust our ears. Others have to rely on seeing and preconception.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th May 2012, 02:20 AM   #23486
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
The issue being addressed by this extra complication is of current flow into an imperfect "ground". If grounds were perfect, that is, if no impedances common to dirty sources and clean signal existed, then there would be no issue. Not knowing your circuit, but trusting your abilities, I can only comment that a star ground with no ground loops is "perfect" in this respect.
If a power supply has a "power supply ground" and a single ground wire running over to meet signal ground imbalance currents flow through it. This is then *not* a star ground. If OTOH a power supply of however many parts each completely floats, then no current except that drawn by the loading amplifier flows into "ground".
Thanks,
Chris
Old 30th May 2012, 02:27 AM   #23487
Wavebourn's Avatar
Chris, once more: The Ground is where Outputs of voltage stabilizers are connected together. Al wires from transformers to that final point are FLOATING. No ground loops. Except through capacitances between secondaries to the shield between them and primaries. But this loops are closed through themselves, and voltage drops on them are not applied anywhere.
Old 30th May 2012, 02:28 AM   #23488
Steve Eddy's Avatar
What about currents flowing into your reservoir caps? Is everything that comes after the transformer secondary going to be perfectly symmetrical?
se
The Audio Guild
Old 30th May 2012, 03:32 AM   #23489
hitsware is offline hitsware
se
........... I've been swamped before ........
Old 30th May 2012, 03:39 AM   #23490
john curl's Avatar
That's another 'secret' SE. Of course, you or SY will not think much of it, so I think I will leave it off the list. I'm tired.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
