The Lounge A place to talk about almost anything but politics and religion.
Old 28th May 2012, 09:43 AM   #23391
DF96 is offline DF96  England
Originally Posted by john curl
I should go out of my way to . . . Have I gotten this right?
No, not really. You seem to be exaggerating a minor point.
All this talk of hole size wrt wavelength partly misses the point. We don't have a hole, we have a hole plus wire poking almost through the hole. Inside the cage there will be a rapidly decaying (evanescent?) field from the hole, but it doesn't become zero imediately. Poke a conductor into that space immediately behind the hole and you can sample the EM field just outside the cage. To make a good Faraday cage you need small holes (wrt wavelength) and nothing inside the cage too near a hole. A regular array of holes is called a diffraction grating, so you could get effects which depend on exactly which direction you hold your phone.
A plastic light tube would probably be fine, unless it acted as a dielectric resonator. Isolating the wires would work - chokes or feedthrough capacitors. Making the circuitry itself relatively RFI immune would also help. I think it is unlikely that adding a panel LED to a well-designed circuit will seriously damage the sound. If it does, then the circuit needed better EMC performance anyway so the LED was a useful diagnostic tool.
Old 28th May 2012, 01:29 PM   #23392
On Hiatus
SY's Avatar
Originally Posted by Wavebourn View Post
3 mm is approximately 1/20 wavelength of 5.8 GHz. I have chassis made of perforated aluminium, full of such holes. Still, no radio reception.
Likewise. Quite a few classic and excellent amps even have tubes on top of the chassis.
Then again, I don't use my cell phone while doing critical listening, its presence next to my left ear unbalances the imaging.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 28th May 2012, 03:24 PM   #23393
PMA is offline PMA  Europe
PMA's Avatar
But he has INSULATED I/O connectors on the rear panel with all those cables going "through the hole" inside the preamp and this is fine??
You guys are exaggerating problems that do not exist and overlooking obvious issues, this is so usual in audio design.
Old 28th May 2012, 04:39 PM   #23394
dennis h is offline dennis h  United States
Thanks PMA , a simple search of PMA as the author and "connnector" as the subject brought me a whole new world to ponder...
dennis h
Old 28th May 2012, 04:43 PM   #23395
john curl is offline john curl  United States
john curl's Avatar
What I am being 'criticized' for not adding an LED. '-)
"Condemnation without Examination is Prejudice"
Old 28th May 2012, 04:48 PM   #23396
jacco vermeulen is offline jacco vermeulen  Netherlands
jacco vermeulen's Avatar
Send a message via Yahoo to jacco vermeulen
Mr Curl,
looks fine to me, without the LED.
Why does it hurt when I Pee ? (Ay Ay Ay https://www.youtube.com/watch?v=w5fLGWrHouk)
Old 28th May 2012, 04:49 PM   #23397
On Hiatus
SY's Avatar
No, your questionable reasoning was criticized, not you.
Old 28th May 2012, 06:58 PM   #23398
No, just explaining why an LED in a high RFI environment apparently giving rise to audio problems does not mean that LEDs damage sound but it could mean that the wires to the LED are breaching the screen. This is to correct two opposing views:
1. LEDs damage sound. (No they don't, but the wires might if there is poor EMC performance elsewhere in the circuit.)
2. A panel LED can't possibly damage the sound. (True for the LED itself, but it needs wires and they might have an effect.)
I agree that it is likely to be a small problem.
Of course, other wires might cause problems too but we are not talking about other wires.
Old 28th May 2012, 07:01 PM   #23399
john curl's Avatar
My questionable reasoning has made me very well known and respected as an audio designer. The Vendetta Research phono stage had the same dilemma and we never added an LED, as well.
Old 28th May 2012, 07:09 PM   #23400
PMA's Avatar
It would be nice to distinguish between important and unimportant issues. As usually, unimportant 'issues' attract much more attention than necessary and important issues are not discussed.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
