The Lounge A place to talk about almost anything but politics and religion.
Old 27th May 2012, 03:35 AM   #23311
john curl is offline john curl  United States
john curl's Avatar
Thanks JCX, of course, that is the main reason.
"Condemnation without Examination is Prejudice"
Old 27th May 2012, 03:54 AM   #23312
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Originally Posted by Joshua_G View Post
Chris Sugar, thank you for sharing. Your experience is illuminating.
Yes, it illuminates what happens when Prodigy Pro guys copy different parts of different examples of famous equipment mixing them together.
The Devil is not so terrible as his math model is!
Old 27th May 2012, 03:57 AM   #23313
jam is offline jam  United States
jam's Avatar
Chris Sugar has made a valid observation not so much in the defense of John Curl so are some of you going to ridicule him because of it or is refuting everything John Curl says the main sport of the day.
Sometimes I feel that a bunch of you need to grow up................If you disagree say so, state your reasons and move on
Jam
Old 27th May 2012, 03:59 AM   #23314
On Hiatus
SY's Avatar
I did. So did DF96. Any questions?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 27th May 2012, 05:25 AM   #23315
jam's Avatar
To the outside observer it looks like some sort of Vendetta................no pun intended.
So Mr.Curl does not want to use an led.........lets not make a federal case out of it.
http://www.youtube.com/watch?v=Tym0MObFpTI
Jam
Old 27th May 2012, 05:43 AM   #23316
chrissugar is offline chrissugar  Romania
Originally Posted by hitsware View Post
Do your monitors have 2 or 3 wire mains connection ?
3 pin IEC. I tried to disconect the earth pin just to see if it is a case of "standing on one leg" antenna situation (this was the reason I mentioned the room is 25-30meters above earth) but no there was no difference. Also didn't mentioned that before I opened the speakers for inspection I tried to do different power cleaning tricks. Even used an isolation transformer with screen between windings to eliminate the capacitive coupling of RF garbage. No improvement.
Originally Posted by Chris Hornbeck View Post
Re-connecting with a resistor or a conventional forward-biased diode in place of the LED would narrow the mystery, but probably not worth the effort after all the grief it's already put you through. My money's on injection into the ground, but you've doubtlessly figured something along those lines.
This was long ago and finding the problem after so much frustration was such a relief that I didn't bother to check if just desoldering one pin of each LED would solve or not the problem. Of course it was a case of injecting garbage into ground.
What I shared was simply my experience and in no way you should take it like my intention to defend John Curl. Sincerely , although I respect him for what he done in audio, most of the time I find his claims related to various problems being unacceptable.
I think in general, audiophiles observe certain audio phenomenons but most of the time they associate wrong conclusions to the problem.
I do not exclude that my observation that the LEDs were the source of problem is wrong and the wires connecting them were injecting RF into the active speaker but after doing all those tests with ferrites, capacitors etc, it is the only sane reason I can find. But I repeat again, I'm open to accept my conclusion is wrong. Probably one day I will redo the experiment just to see if the LED were the source of problem or the wires
I do not understand what are you talking about. Is this just a cheap shot? I was talking about two devices made by prestigious manufacturers that behave wrongly even if they are not connected to anything only powered.
Most of my mastering tools are designed by myself and very few of them recycle old and good ideas, but mostly they are designed from scratch. And by the way my devices do not produce any problems in that RF polluted environment.
chrissugar
Old 27th May 2012, 05:53 AM   #23317
jam's Avatar
I never did say I agreed with everything Mr.Curl says but but i would not keep attacking him if I disagreed with him.......but beware that you don't find yourself on the wrong side of the fence if you agreed with him.
Jam
Old 27th May 2012, 06:36 AM   #23318
Wavebourn's Avatar
I believe you.
Forward biased by 10 mA current diode demodulates RF inside of the box full of semiconductor devices with nanoamp input currents?
Don't make my slippers laugh please. Most probably that innocent LED was soldered to the ground in wrong place, so it's wire acted as antenna.
Old 27th May 2012, 06:43 AM   #23319
PMA is offline PMA  Europe
PMA's Avatar
Jam
Same for you, dear Jam
Old 27th May 2012, 06:55 AM   #23320
You should read carefully what I wrote.
1-only one LED of the two is forward biased the other only conduct when there is an over (which never happens)
2-the two LEDs are 20 cm outside the Faraday cage on the wood front panel (not inside the Faraday cage with all the other semiconductors)
3-the speakers (drivers) are connected with 20cm wires to the Faraday cage and they do not induce RF.
chrissugar
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
