The Lounge A place to talk about almost anything but politics and religion.
Old 19th April 2012, 04:10 PM   #22481
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by Wavebourn View Post
Referring to the data that chalenges beliefs indeed may be perceived as an attack.
And you have attacked others who did so.
My point was to show you your own reactions to demonstrat that if somebody is scientist it does not mean that he/she is free from such reactions, and the fact that somebody is scientist can not be used as proof that he/she is right speakng about perception of sounds.
No, that is not what you did. You attacked ALL scientists and called them arrogant, you attacked me and called me a liar.
What you are now doing is backing up and trying to make others believe that which you think looks better. Luckily, this forum stops editing after 30 minutes, so the past cannot be re-written.
Had you first stated such, I would have been in complete agreement with you. But you did not..
Now, go back and re-read my posts. I have described significant issues I have with the test regimens being used to show audibility nulls, I believe audiophiles are at a significant disadvantage in this regard.
Now get over yourself... go back and re-read everything I've stated. For whatever agenda or reasons you may have, you have mis-categorized me as an anti-audiophile..
And I am not.
j
Old 19th April 2012, 04:15 PM   #22482
simon7000 is offline simon7000  United States
Originally Posted by SY View Post
Did you know that I have solid evidence that people with longer arms score better on math tests? I am 100% serious here, I am not making that up.
I don't think the issue is with "arm" length here. Something shorter is being compared.
Old 19th April 2012, 04:17 PM   #22483
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Here you go John:
Originally Posted by jneutron View Post
As one of science, the first question scientific reasoning requires is: ""Prove your assertions under conditions which remove expectation bias"".
Audiophiles seem incapable of providing such under controlled testing regimens.
However, also as one of science, I have examined the testing methodology used to date and find it lacking rigor. Confounders which are not understood are simply ignored as a result. I therefore cannot consider lack of positive results as proof of no difference..
Do not mistake me. I do not consider everything as audible, just that the tests which indicate such may be flawed.
j
The Devil is not so terrible as his math model is!
Old 19th April 2012, 04:18 PM   #22484
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
Just as a point of order - if there's evidence of arrogance and a falsifiable definition of it extant, then it needn't be an attack to call a person (or group) arrogant - it can be merely a description.
Not confirming or contesting this particular case as I haven't read Wavebourn thoroughly enough to evaluate if these two criteria have been met.
Calling a person a liar I think cannot meet the falsifiability criterion so must be assumed to be an attack.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 19th April 2012, 04:27 PM   #22485
Wavebourn's Avatar
Sometimes it is not necessary to call a person liar to make him believe that he was called a liar. Also it is not necessary to call all scientists "Arrogant" to make him believe that all scientists were called "Arogant". Enough to refer to data that challenges his belief, and to insist on examining of this data instead of attacking the messenger.
Old 19th April 2012, 04:45 PM   #22486
elektroj is offline elektroj  Europe
.... and the fact that somebody is scientist can not be used as proof that he/she is right speakng about perception of sounds.
Old 19th April 2012, 05:05 PM   #22487
john curl is offline john curl  United States
john curl's Avatar
Wavebourn, I agree with your argument, and JN uses 'exaggeration' of whatever statement you make to make it turn against you. He has done it to me for years. I just don't bother to 'debate' him, anymore.
"Condemnation without Examination is Prejudice"
Old 19th April 2012, 05:09 PM   #22488
KBK is offline KBK  Canada
Yes, I was aware of this. Backster is one of the people who have been hyping the use of polygraphy for decades. Too bad it doesn't actually work... See David Lykken, for example.
For your amusement:
The Straight Dope: Do plants have ESP?
And some guys local to you:
Annotated Mythbusters: Episode 61: Deadly Straw, Primary Perception
You got catch 22'd by an emergent point in physics research, regarding quantum aspects.
That consciousness (directed-intent) directly affects the local medium.
Therefore, expectation bias ended up in the trashcan, as does studies done on psychic phenomena, by people who have no belief or trust in it.
That studies done on psychic phenomena by people who believe and understand it, are successful, every time.
And that the exact same studies, conducted in the exact same way, by non believers, fail, every time.
That the given studies, checked for possibility of inaccuracy or issues of testing regimen and design, are found to be perfectly suited and of excellent scientific protocol, regarding potential for false results or anomalous results.
Ie, the studies are fine, the people in them are the issue.
That consciousness directly affects the local medium.
Thus, science is caught by the bias inherent in the mind conducting the given science.
That independence from the results, at the reality formation point itself...is impossible.
The thing that was inevitable, even by the rules of science itself, has happened. That science is brickwalled by itself. brickwalled....by the given people within it.
"Extraordinary claims require extraordinary evidence." - Carl Sagan. Sometimes the claims aren't extraordinary. Sometimes the weakness of men's minds are the culprit. Mass mentality has nothing to do with obviousness or truths.
Old 19th April 2012, 05:19 PM   #22489
Wavebourn's Avatar
The problem is, no matter how many of respected scientists check that studies "for possibility of inaccuracy or issues of testing regimen and design", results of their studies are unknown to the majority. Either they loose cridibility as the result, or refuse to admit them to the general public, in order to save own good names and carreers.
Old 19th April 2012, 05:19 PM   #22490
On Hiatus
SY's Avatar
That correlates as well, as it happens.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
