The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 18th March 2012, 04:15 PM   #21471
johnferrier is offline johnferrier  United States
johnferrier's Avatar
Concern about loudness levels aside. The intriguing thing about headphones is that it is much easier to attain concert levels using headphones than loudspeakers. As SY's indicated in the past, I doubt my family and neighbors want to me to replicate the sound of a full orchestra (at concert levels) in the living room. (And I cannot imagine what Nirvana live From the Muddy Banks of the Wishkah might do to the neighborhood.)
Michael Gazzaniga - "The arts are not frosting but baking soda."
Old 18th March 2012, 04:26 PM   #21472
bcarso is offline bcarso  United States
diyAudio Member RIP
Note: for those who may be wondering, and apologies if I missed the specifics earlier, this is the "Solomon" I believe mentioned by JC: http://www.ti.com/lit/an/snoa737/snoa737.pdf
Brad
Old 18th March 2012, 04:33 PM   #21473
john curl is offline john curl  United States
john curl's Avatar
Of course, Johnferrier. We don't want to hurt people's ears, we just want to make sure that the headphone amp doesn't clip. One, 'equalizer' is using a 30 ohm build-out resistor, as I have already suggested. This way, a really sensitive 30 ohm headphone will have its output reduced by 6dB. Not a bad idea. It also keeps the design more class A until voltage clipping is possible, and hopefully not often reached.
"Condemnation without Examination is Prejudice"
Old 18th March 2012, 04:37 PM   #21474
john curl's Avatar
Thanks bcarso, yes, that is the article that I keep handy, and have done so for almost 40 years.
Old 18th March 2012, 04:45 PM   #21475
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
John,
Originally Posted by john curl View Post
I'm a Class A kind of guy! '-)
My preferred way of making a "low impedance load driver for Op-Amp's" has a similarly low parts cound and is also targeted for 100...200mA Iq.
I like low beta, high Ft Bipolar's as direct follower with a CCS in the tail, an LM317 is surprisingly good (I have seen people use them a anode loads for ECC88, I would not go THAT far).
A total of 3 parts (2SC5171 or 2SA1930 depending if we want to pull the Op-Amp output up or down to put it into SECA, LM317 and one resistor) and we are SE Class A, including the Op-Amp output.
I know it's brutal, basic and simple...
Hang the PNP version of this of pin 5 of a real NE5534 and use a heavily degenerated 2SK/LSK389 with CCS tail and cascode as input stage bypassing the internal one and you will have a surprisingly nice Linestage or headphone Amp using the dreaded NE5534... Or take the degeneration out for a Phono Stage...
Ciao T
Old 18th March 2012, 04:58 PM   #21476
diyAudio Member RIP
OT here, but for anyone else subscribing to or reading the Sound Quality vs Measurements thread, are you experiencing the ads rapidly refreshing at the top of the page and each time returning one to them, and preventing reading new posts? I've PM'd a moderator and as well posted a complaint in the standard place. Maddening! And having donated I understand I'm even supposed to be able to kill ads althogether, although I have no idea how to do this.
This thread at least is unaffected for now
Old 18th March 2012, 06:27 PM   #21477
On Hiatus
SY's Avatar
I haven't been able to duplicate the issue; have you tried clearing your cache?
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 18th March 2012, 06:50 PM   #21478
diyAudio Member RIP
It vanished after about four visits (but persisted for a few before that). The behavior was only on the Sound Quality thread, not this one or others. I have no idea what was going on. However, having donated, where do I go to turn ads off?
Last edited by bcarso; 18th March 2012 at 06:52 PM. Reason: wrong thread referred to
Old 18th March 2012, 07:06 PM   #21479
john curl's Avatar
If I can go on, what IC should we use? What do we want to select for? Many IC's have different idle currents, and this effects the Iq. What to do?
For the record, the humble uA741 works pretty good in this amplifier. Amazing isn't it? Why?
Old 18th March 2012, 08:05 PM   #21480
JC,
Are you actively building this design in your lab now, are you brainstorming, or is this just a thought experiment for the forum ? FWIW, I thought the OPA627/637 were nice chip op-amps. (Although, as I've posted before, in the end I went with Borbely's design.)
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
