The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 13th December 2011, 03:05 AM   #19141
john curl is offline john curl  United States
john curl's Avatar
As usual, strong comments are made without any experience.
Let me give you one example of MY experience with line cords.
Personally, I don't like to spend extra money on line cords, but that does not say they are not audible. Please don't 'knock it' if you haven't tried it.
In any case, I had an interesting experience about 20 years ago, at CES.
A music producer that I had worked with since 1977, off and on, was doing an A-B test with power line cables.
Now, I had known and worked with this guy through 3 enterprises that he created. First, in the late 70's he had an audio magazine that I once contributed to.
At the same time, and after, he started and ran 'Crystal Clear Records' a direct disc recording company with many, many titles. I designed the electronics for his recording desk back in 1977. John Meyer (of Meyersound) was his technical consultant and he and I both recommended B&K 4133 condenser microphones running at full voltage.
A listening example of our efforts was: 'Arthur Fiedler and the Boston Pops' made in 1977 with direct disc mastering.
Anyway, he was at CES and was demoing power cords about 20 years ago.
Did we hear a difference? Yes we did, but he wanted so much money for these cables that we 'wrote it off'. Yet, the difference was there, AND for someone with means, actually a bargain for the improvement in the sound, which is difficult to get, once you have really good equipment, already. To say it is BS, is unfortunate. Live in ignorance, then. '-)
"Condemnation without Examination is Prejudice"
Old 13th December 2011, 03:35 AM   #19142
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
Are you saying John that John Meyer can confirm your finding about power cords?
Nothing in the universe is perfect. The ideal things are the ones that are most optimal. Optimization criteria, what matters. When I hear "No Compromise Design", I want to take a sledgehammer and test how impact-proof it is.
Old 13th December 2011, 04:09 AM   #19143
john curl's Avatar
No, John Meyer and I have not worked together for decades. He tends not to believe things like this. No, I was with a different set of associates.
Old 13th December 2011, 04:14 AM   #19144
Johnloudb is offline Johnloudb  United States
Johnloudb's Avatar
Originally Posted by pski View Post
Please refer to Ohm's law concerning your old 15 amp AC. The wire in the transformer? GEEZ. It's the winding, not the gauge.
I think you completely missed my point. Yes, it's the number of turns in the primary that determines impedance. There's this thing called mutual inductance. The load applied to the secondary affects impedance too. And to say any more I have to dig out an old textbook, cause I don't remember all that stuff now.
So, if a person shorts the output of the secondary and the core starts to melt, the wire inside the transformer will still be a long wire and the gauge much less than a 6mm.
Hmmm ... so how the F#@$ does having a 6mm AC line help anything?
My Website: Hyperacusis, Tinnitus, My Story
Old 13th December 2011, 04:20 AM   #19145
zapnspark is offline zapnspark  United States
zapnspark's Avatar
Here's a link to some history of early digital recordings.
It includes additional information on Crystal Clear Records and other items that John C. has mentioned.
http://goo.gl/rtn39
Just thought this might be interesting to some of you folks.
Cheers.
ZAP
Old 13th December 2011, 04:27 AM   #19146
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
how do you justify using a gage#11 power cord on an amp that has a power traffo with primary winding using gage#20 and then plug that power cable into a wall outlet that has a gage#14 cabling?
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 13th December 2011, 04:35 AM   #19147
PMA is offline PMA  Europe
PMA's Avatar
You have very true signature, Tony.
Old 13th December 2011, 05:22 AM   #19148
VladimirK is offline VladimirK  Uzbekistan
I would like to attract attention once again to chokes in power supplies of AB amps. Maybe some substractions from a textbook (its in russian) could help me to explain the point: chokes (10mH and more) help a bit to have more favorable spectrum of charging pulses, but they do increase voltage drops at filter capacitors during current consumption peaks and affect negatively sound dynamics.
As a conclusion, chokes are not recommended for AB amps, except for maybe configuration shown in fig.36, with external or well screened part of PS, and with abnormally big C3 and C4 (in order to compensate negative effects of chokes)
Old 13th December 2011, 05:36 AM   #19149
john curl's Avatar
You are correct, Vlad. We call Fig. 36 a pi filter, in the USA. CLC
Old 13th December 2011, 05:47 AM   #19150
Wavebourn's Avatar
Vladimir; there are some other Russian books, for example: http://www.znvo.kz/images/book/dobrotvorskyin.zip
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
