The Lounge A place to talk about almost anything but politics and religion.
Old 19th November 2011, 07:54 AM   #18081
PMA is offline PMA  Europe
PMA's Avatar
Originally Posted by john curl View Post
Don't worry PMA,
I don't. I assume that many are happy with 64kbit/s mp3 and would find it indistinguishable from master tape or 192kHz/24bit in a well controlled, scientific A-B-X test
Old 19th November 2011, 08:14 AM   #18082
john curl is offline john curl  United States
john curl's Avatar
If you would want Bob Pease's article you should Google: 'The best of Bob Pease'. It should be there. I find the article useful.
"Condemnation without Examination is Prejudice"
Old 19th November 2011, 08:23 AM   #18083
PMA's Avatar
Thanks, I have had the article for several years. Very good, lot of real experience.
Old 19th November 2011, 08:36 AM   #18084
PMA's Avatar
The problem we had with the polyester cap was similar (shape) to the attached simulation, but settling time was longer, in us. The 'overcompensation' or 'undercompensation" was not the case, it was impossible to tune it by R,C values (R//C-R//C) divider. It was fixed with polypropylene caps.
Old 19th November 2011, 08:55 AM   #18085
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
That would show up nicely on our bridge null test. An historical point, a professor from SUNY sent a very nasty letter to Ed Dell and in essence he denied the existance of any effect rather that deal with the issue. I think a lot of folks get to this point. I was in the middle, there is an effect and I don't see anything going on that is audible except in the grossest context. The talk of "memory" and "echo" was unfortunate and inaccurate, and I did not want to support it.
The same issue arrises with cap distortion. Folks measure distortion with considerable AC on the cap and extrapolate that to performance where there is no AC on the cap (coupling well past 3dB, bypass).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 19th November 2011, 09:55 AM   #18086
Bonsai is offline Bonsai  Europe
Good points about the AC voltage across the cap Scott. You do need to keep it very low to avoid the distortion.
Old 19th November 2011, 10:03 AM   #18087
PMA's Avatar
Probably yes, as the issue we had was more related to frequency dependence of capacitance of the polyester capacitor. For the R//C-R//C voltage divider the DA is not that much an issue (parallel resistor). But is a GREAT issue in the (R-C)-(R-C) divider (series damped capacitive divider). I was building these dividers for HV impulse voltage measurement, and I have been aware of the DA problem since the beginning of the 80-ties.
Old 19th November 2011, 10:48 AM   #18088
PMA's Avatar
Variation of capacitance with frequency for several cap types. MKN is polyethylene, and this makes biggest troubles regarding step response. It is impossible to make proper step response compensation with this cap, as the response is both over and under compensated.
Old 19th November 2011, 11:21 AM   #18089
On Hiatus
SY's Avatar
Nonsense. Or sloganeering, your choice.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th November 2011, 11:40 AM   #18090
On Hiatus
SY's Avatar
MKN is polyethylene
No, it's not. MKN is generally PEN, a type of polyester. Polyethylene is rarely used as a dielectric (despite superb dielectric properties) because of its low melting point.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
