The Lounge A place to talk about almost anything but politics and religion.
Old 17th November 2011, 09:20 PM   #18041
wayne is offline wayne  United States
In the hills
Originally Posted by john curl View Post
the Korg 2000, which is a better product than most here use. It would appear to this engineer that it is the ANALOG part of the electronics that is the primary weakness. Digital seems to be working as expected. Perhaps that is a good part of the bass problem.
I was struck by how good the thing is stock out of the box. I don't really like DSD for a few reasons but it works in this case. Good to know it could be improved upon.
Old 17th November 2011, 09:21 PM   #18042
simon7000 is offline simon7000  United States
Originally Posted by SY View Post
No, but I do know a few things.
Yes, I'll allow the philosophical possibility that someone has set up a controlled listening test, demonstrated the audibility of an ADA chain, then not published this remarkable result anywhere.
That is almost done all the time in most recording studios. They listen to the live mix and monitor what comes back from the recorder. When it doesn't sound close enough, they gotta play. Usually with send levels, sometimes with swapping gear, rarely with hot metal tools.
No double blind, no statistical control, just "Engineer'" ego err skill.
Old 17th November 2011, 09:23 PM   #18043
On Hiatus
SY's Avatar
Level for sure- one way to match levels is to adjust them until, in a blind comparison, you can't distinguish A from B.
I'm sadly familiar with recording engineer egos.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 17th November 2011, 09:27 PM   #18044
Actually the send level if too high on live recordings is the major source of distortion.
I am unfamiliar with the concept of too large an ego as they are all smaller than mine.
Old 17th November 2011, 09:36 PM   #18045
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Arf!
And too, the technical requirements for analog electronics connected to digital convertors are insanely high. Giant spikes with vertical risetimes, everything fast and loose, lots and lots to go wrong. But things are getting better mostly. Really needs vacuum valves to be conservative, but good enough is good enough.
Thanks,
Chris
Old 17th November 2011, 09:37 PM   #18046
Pano is offline Pano  United States
Pano's Avatar
Guess it depends on the A/D/A. It was easy to hear the DCX2496 when inserted into the tape loop. I blame the analog section tho, not the digital.
Old 17th November 2011, 09:41 PM   #18047
Probably not. It seems it depends mainly upon the ears used to observe what is going on. There really are some folks who don't notice. MP3 forever or some such.
Old 17th November 2011, 10:02 PM   #18048
On Hiatus
SY's Avatar
Jan had the same problem until he figured out that it was... ta-daa! the gain structure.
Old 17th November 2011, 10:40 PM   #18049
vacuphile is offline vacuphile  Netherlands
vacuphile's Avatar
I picked up word from the street that SY once took part in an informal ABX-listening test of original vs. 3 differently compressed MPEG's, and that he was the only one that ranked them in the right order. Some engineering sense does not stand in the way of having fully operational ears, apparently.
vac
But from now on I will be discrete about it.
Old 17th November 2011, 11:15 PM   #18050
Pano's Avatar
Was that the test were I also got them in the right order? No, that's was Jan's test.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
