The Lounge A place to talk about almost anything but politics and religion.
Old 16th November 2011, 11:34 PM   #18001
john curl is offline john curl  United States
john curl's Avatar
Too many series unbiased series caps in the Korg.
"Condemnation without Examination is Prejudice"
Old 16th November 2011, 11:50 PM   #18002
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by gurevise View Post
Can you elaborate about "ground contamination caused by the (series) power supply regulators" ? Is it a rectifier diode switching noise or something else?
Sorry, wasn't well explained. Nakamichi used a pair of FETs as source followers to supply DC (and ground) to the *other* polarity's local zener diodes, gates connected to ground. True clean grounds in consumer electronics are made of unicorn horn, so this element at least kept dirty currents away from local ground. Folks enamoured of "shunt" supply regulators need to think about grounds just as much as anybody, maybe more.
Thanks,
Chris
Old 16th November 2011, 11:53 PM   #18003
scott wurcer is online now scott wurcer  United States
scott wurcer's Avatar
The pure PWM output doesn't bother you? Feed it right into your power MOSFET's and your done (perfect sound forever, finally?)
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 16th November 2011, 11:58 PM   #18004
john curl's Avatar
Isn't that nice!
Old 17th November 2011, 12:35 AM   #18005
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I use a Kork MR-1000 with a pair of Microtech Gefell ORTF mics straight into the box. It sounds pretty damn good. When i make down sampled CDs from the master the main difference is in the bass. The master sounds a bit fuller, warmer and spacious.
Old 17th November 2011, 12:54 AM   #18006
Of course.
Old 17th November 2011, 01:06 AM   #18007
Yes, that is really strange but i hear nothing over 16kHz. Martina Schoener of Garrard-Loricraft hears much better in the treble then me though. Just today she was complaining about a preamp i build her. With the volume control in a certain position she could hear a crackling noise when i moved the control back and forth. Me with the ear at the tweeter heard ( you guest it ) .... nothing
Old 17th November 2011, 01:28 AM   #18008
.... nothing
Monty Python . Spot the Looney - YouTube
Old 17th November 2011, 02:03 AM   #18009
anatech is offline anatech  Canada
anatech's Avatar
Hi Scott,
The Nak 1000ZXL machines could really do a good job. Getting rid of the felt pressure pad on step one (no more FM scrape noise). They really did understand analog electronics very well. Some of their CD players used similar methods, and not just the reference ground measures. I still have an OMS-7 (14 bit) that sounds great. I'd love to route the RF signal into a modern chip set and PCM-1702 or better.
Did the Nak analog guys mention anything else of interest? Doing service for many brands, Nakamichi was one of those that I was eager to see new designs from. Most other brands later on were pretty much more of the same inexpensive stuff. Ho-hum.
Hi Chris (Hornbeck),
A lot of the following is for people not familiar with the concepts that Nakamichi used.
Nakamichi also did the same thing with BJTs. Use the ground as a reference and pass the actual operating current to the other supply. To explain this better, a normal regulator sends it's own operating current into the ground it uses as a reference. Nakamichi did two things that were important to this idea. The first was that these regulators were local to the circuit, right at the point of use. They used ground for a reference only, and passed their operating current (with it's fluctuations and input noise) off to the opposite rail before the complimentary regulator. The other related concept was that the absolute voltage was not important. What was important was that the voltage drifted very slowly and did a good job of blocking any noise on the supply. One example of engineering trade-offs made to optimize what was most important.
Now, what noise would there be on the supply rails? After all, these supplies are already regulated. Just as there is a finite impedance in what you call "ground", there is also in the power supply wires and foil. That leads to minute voltage variations due to the demands of anything else sharing that supply (I*R), and also what can make it through the first stage of regulation. These power supplies can also pick up radiated noise along the way inside the chassis. Whatever you want to call this collection of noise, you'd best get rid of it before feeding a high gain stage - like a tape head EQ amp, or maybe the analog stages immediately following a D/A converter. You can make the same argument for the clocks in a CD player, and the I/V converter that processes the signals from the photo-diodes.
There is more than one way to "skin a cat", and this method is pretty powerful if used with the same detail as the rest of the circuits involved.
I would have absolutely loved to have seen a Studer 24 track that utilized Nakamichi designed electronics. That would have been totally amazing! Only a Studer transport would make this worthwhile in my view.
-Chris
"Just because you can, doesn't mean you should" my Wife
Old 17th November 2011, 02:32 AM   #18010
hitsware is offline hitsware
Assuming no xover issue nor shoot thru ..........
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
