The Lounge A place to talk about almost anything but politics and religion.
Old 30th October 2011, 07:04 PM   #17131
Chris Hornbeck is offline Chris Hornbeck  United States
Chris Hornbeck's Avatar
Originally Posted by simon7000 View Post
Gee,
The dither math I've looked at shows that you also have to account for the sampling bandwidth. So at upper midrange frequencies (where the ear is most sensitive) a perfect dither will only allow the equivalent of 19.5 bits of resolution.
If you have a different math treatment I'd be interested.
Sorry, I have no idea what you're talking about.
Chris
Old 30th October 2011, 07:07 PM   #17132
On Hiatus
SY's Avatar
You've illustrated by earlier point perfectly. As long as we consider signal-to-noise, noise floor, and resolution as being the same thing, we can make all sorts of incorrect conclusions.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 30th October 2011, 07:10 PM   #17133
simon7000 is offline simon7000  United States
Originally Posted by SY View Post
You've illustrated my earlier point perfectly. As long as we consider signal-to-noise, noise floor, and resolution as being the same thing, we can make all sorts of incorrect conclusions.
How do you distinguish between ultimate S/N (dynamic range) and number of bits for a given bandwidth?
Old 30th October 2011, 07:27 PM   #17134
On Hiatus
SY's Avatar
You used the term "resolution," then used an equation for dynamic range. You'll have to define "ultimate S/N" to get a sensible answer, and it is not the same as "dynamic range." "Number of bits for a given bandwidth" is another fuzzy term. I don't mean to be pedantic, but if you're going to be quantitative, you have to be clearer about what you're calculating.
Old 30th October 2011, 07:39 PM   #17135
jcx is offline jcx  United States
weighting has already been mentioned but some (Dolby?) use ITU-R 468 instead of "A" so more care is going to be needed in the cassette vs CD comparison - where are you puttting cassette tape peak = digital 0 dbfs, @ 30% 3rd harmonic??
Old 30th October 2011, 08:07 PM   #17136
If you do an ANSI standard articulation test of a cassette recording vs a 16 bit digital stream at peak modulation of 100% they measure the same. If you reduce the peak modulation to 1% they still give the same results.
I am not comparing CD to cassette just pointing out that with our hearing mechanism a high performance dolby cassette will yield the same results as a 16 bit linear dsp system.
SY,
I use 20 log (2exp (#bits)) to give a digital equivalent to the Ultimate S/N ratio of an analog system. Ultimate S/N is from the noise floor at 15.9k bandwidth to clipping. Clipping is when the peak output voltage of the DUT is reached and is roughly equal to 5% distortion of a sine wave. This is pretty much the way the engineers I work with measure things.
What seems to be missing is an understanding of monoticity. An "X" bit linear D/A will have the most significant bit and all lesser bits accurate to the least significant bit. But the least significant bit will not be any better. So on an 8 bit D/A you will have 256 levels but if it is putting out 2.55 volts full scale the step size could be .01 volts but when the LSB is toggled it is more likely the change is .049 or .0149 volts. That is why dither does allow more information to pass but at a rising rate of distortion.
Resolution of an "X" bit D/A is as used by my cronies is 1/(2 exp "X").
S/N is the ratio from a standard operating point for Analog this is defined as 0 db(x?) and that is often based on the voltage equal to 1mw into 600 ohms, but not always. The peak operating level is then specified with a given distortion. As the limit is clipping the difference between .1%, .3%, 1% and the traditional 5% is very small, but different folks use different spec.s (.1% to 5% often has a difference of .4 db!)
S/N for a digital system has become from 1/2exp(Bits) to Full scale.
Ultimate S/N as mentioned is from the wide band noise floor (15.9K) to clipping. I use 5% when I make a measurement. To me this is the same as dynamic range.
So far there have been issues with i vs I and Sabin vs Sabine, and other of what I always thought was standard nomenclature.
ES
Old 30th October 2011, 09:03 PM   #17137
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
For historical interest this was one of the first test disks from CBS/Sony in 1983. They did not always believe in dither.
Of further interest the "pop" music sample is Johnny Rotten in a Tokyo PIL concert. PIL = Public Image LTD. not exactly bluegrass.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 30th October 2011, 09:39 PM   #17138
Checking further this is a true artifact part of the initital CD rollout.
Old 30th October 2011, 10:11 PM   #17139
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Leibnitz invented digital so relax Scott.
Old 30th October 2011, 10:24 PM   #17140
Actually the Jesuits invented digital in the 17th century, even Shirley knows that.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
