The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 29th October 2011, 01:21 AM   #17071
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Well, this one is actually not PCM but it claims an analog SNR of -116dB.
Grimm AD1
Old 29th October 2011, 01:22 AM   #17072
http://www.grimmaudio.com/product_info/Manual%20AD1.pdf
Old 29th October 2011, 01:28 AM   #17073
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
-116dB is still a substantial distance above 24bit quantization noise. It's equivalent to around 20bits.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 29th October 2011, 01:30 AM   #17074
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by simon7000 View Post
Now if you allow the premise that some humans (I know a presumption on my part) can perceive distortions of -140 db to -160 db re the peak sound pressure level, then many of these issues would actually have a basis!
I don't. There is no evidence in any context for this exaggerated claim. At some point you have to stop sending random resistors to folks and asking for their uncontrolled anecdotal comments and presenting it as evidence.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 29th October 2011, 03:17 AM   #17075
hitsware is offline hitsware
> it as evidence.
And how do you define that 'point' ..........
I'll take some of your samples .....
Old 29th October 2011, 03:28 AM   #17076
> it as evidence.
You make up some test where some resistors measure -140dB vs -150dB distortion and then you send those resitors to a third party and ask them to use them in some circuit and they line them up in your empirical model of what matters. And then you claim this means that stuff at the -150dB level matters.
Old 29th October 2011, 04:02 AM   #17077
john curl is offline john curl  United States
john curl's Avatar
Over the decades, we hi end designers have discussed differences in resistors. Audio designers used to use carbon resistors, sometimes 'lousy' carbon resistors as standard. Allen Bradley in the USA seemed to make a pretty good carbon resistor, and Ampex used them for everything except precision attenuators. Back in those days, a 1% precision resistor might cost the equivalent of a cafeteria lunch.
Still, exceptions were found in resistors that added excess noise or distortion. As our measurements got better, we noticed this more. Richard Heyser pointed this out to me, over 40 years ago. In the 1980's 'HFN' came up with an article that measured distortion in both caps and resistors, AND they even tried to evaluate them by listening. They did a very good article.
In any case, all my best designs include specifying certain resistor brands and size. It is part of the design process for me, and I will stick with it. By some coincidence, one of my favorite resistor brands, the German made 'Resista' the standard component in my Vendetta Research phono stage and the Blowtorch, MEASURES really well, compared to some other Resistors, and they only cost me $.05 in limited quantity of 100 or so. Today I rely on Ed Simon to guide me on what is still available and how well it works.
"Condemnation without Examination is Prejudice"
Old 29th October 2011, 08:05 AM   #17078
chrissugar is offline chrissugar  Romania
The best high-end mastering converters have 127dB SNR that is equivalent to 21 real bits of audio. The remaining 3 bits are noise. This is the maximum that is possible to obtain considering the difference between the Johnson noise and the maximum levels used in balanced proaudio (0Vu = +4dBU vith 24-26db headroom) which is way more than the -10dBV used in unbalanced hifi. So there is no real chance to improve this 127dB, except if the whole level standard would be changed to a much higher one (no chance) or to imerse the whole converter into liquid nitrogen to reduce Johnson noise.
Anyway even if it would be possible it wouldn't matter because the SNR situation is already compromised long before any AD or DA conversion at the microphone and mic preamp.
chrissugar
Old 29th October 2011, 09:20 AM   #17079
PMA is offline PMA  Europe
PMA's Avatar
Permanent mismatch here between narrow band FFT resolution and SNR calculated over whole 20kHz width of frequency band - as in any amateur discussion.
Old 29th October 2011, 10:48 AM   #17080
On Hiatus
SY's Avatar
Well, that and the failure to distinguish resolution from signal-to-noise.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
