The Lounge A place to talk about almost anything but politics and religion.
Old 13th September 2011, 02:37 PM   #15901
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Originally Posted by gpapag View Post
[snip]What is this "a rather new alternative to precise low-distortion, wideband, voltage-mode amplification" ?
[snip][/URL]
... current-mode amplification...?
jan
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 13th September 2011, 02:38 PM   #15902
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Hi Bruno,
Originally Posted by Bruno Putzeys View Post
Back to hiding, Jan Didden asked me to chip in so I hope this is more or less the answer he was looking for.
Before I let you go, you make one interesting statement in your reply to Menno Van Der Veen's LTE: "Conclusion: Negative feedback does not attenuate the harmonics of the open-loop nonlinearity, but of its inverse."
The math is heavy on an empty stomach and I disagree that discounting "distortion of distortion" is right.
Further, there are implications from your conclusions that are no doubt clear to many but I think it may be worth elaborating.
Ciao T
Old 13th September 2011, 02:46 PM   #15903
Scott,
Originally Posted by scott wurcer View Post
I knew this post would come. Yawn, you couldn't be more wrong.
Wrong in what? That your results are NOT results a JC-3 would produce?
I will state, to be clear, the local feedback (2-1M resistors) shown in that circuit do nothing useful.
You mean in YOUR circuit they do nothing useful. What they do in the JC-3 can not be concluded from your sims...
As they say in German "getroffene hunde bellen" (dogs that have been hit bark").
Ciao T
Old 13th September 2011, 03:08 PM   #15904
Bruno Putzeys is offline Bruno Putzeys  Europe
For intermediate values of loop gain "distortion of distortion" may only be "very nearly" negligible instead of entirely. The difference being exactly that between the curved lines and the straight asymptotes in my graph. And your point is?
Occasionally not elaborating every implication spurs people on to think for themselves. That ability comes in handy sometimes.
There's a time for everything, and this is not it.
Old 13th September 2011, 03:18 PM   #15905
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Scott,
Ciao T
WOOF! WOOF! (Or is it woffen woffen wackle wackle mit den hueften) No I meant the JC-3 circuit or for that matter any simple folded cascode gm gain stage like that (whice includes the AD844 and its ilk).
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 13th September 2011, 03:19 PM   #15906
For intermediate values of loop gain "distortion of distortion" may only be "very nearly" negligible instead of entirely. And your point is?
First, given your original "conclusion" it would obvious what.
You note (I have not checked the math but I take it to be correct) that feedback produces an inverse function from original non-linearity of the circuit. What then happens when this non-linearity is applied to the original non-linearity.
Of course, we are back to what some call "re-entrant distortion".
Ciao T
Old 13th September 2011, 03:26 PM   #15907
You are failing to state your case. I am not going to enter a discussion with someone who simply barks "don't agree" without making a counterpoint he is willing to defend.
And just what do you think is re-entrant distortion other than the fact that the inverse of a low-order function has an infinitely long series expansion and hence more harmonics? I just gave you the bloody general mathematical explanation of re-entrant distortion. What will you do next? Tell Newton his gravitational law is incorrect because stuff just falls down?
Old 13th September 2011, 03:42 PM   #15908
Bruno,
Okay, more clearly, as the feedback's distortion reduction based on your math is not a linear function "distortion of distortion" becomes a significant term, not one to be swept under the carpet.
Not quite, you oversimplified. But yes, the mathematical foundation is there. However, have you ever attempted to go through enough iterations to get a precise result? Can the result even be made to converge?
Pullllease, Newton. Pshaw. Newton lived in a Universe that strongly diverged from the one we live in now. And even now, we do not know what gravity is.
Ciao T
Old 13th September 2011, 03:46 PM   #15909
stinius is offline stinius
Jan Didden (janneman) has a great library of famous papers and articles. here
Direct link to the Gilbert paper "Are Op Amps Really Linear?" here
S
Old 13th September 2011, 03:50 PM   #15910
simon7000 is offline simon7000  United States
Back around 1975 there was an interesting article about distortion in cable television amplifiers. Sensitivity to distortion for televisions is not quite as high as it may be for audio, but the bandwidth is so wide that there is a much greater chance for it to occur.
The first example was the normal signal level out of a line amplifier is around 100 mV for each channel. As some systems may have 150 or more channels that could in theory require 15 VRMS out if all the channels were to hit peak voltage at the same time. As they were AM modulated and not in sync that would be unlikely to happen. As the power supply voltage was often 24 VDC the maximum output could only be about 8 VRMS. So there was a minimum power supply voltage required based on probability and VHF transistors of the day had quite low voltage limits. (The solution became bridged amplifiers.)
The second issue was that of IM distortion particularly in multi-stage amplifiers. As the channel spacing is fixed at 6 Mhz. there could be build up of cross products that would affect certain channels.
The third and interesting issue was that sometimes the distorted products of a single stage would have some of the products returned to the correct result by a second stage of amplification (W/ it's distortion).
In audio as you are aware 9th harmonic distortion is particularly objectionable. So where the third order product may be considered adequate at -40 db re the source a 9th order product may not be at -80.
When the error product is included with each stage then each stage's contribution to the final product is more obvious and allows additional design decisions.
Now to me the actual issue on applying classic control theory could be that audio reproduction may be more critical of the small errors than most other control systems. I suspect a gun turret does not require -80 db precision.
ES
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
