The Lounge A place to talk about almost anything but politics and religion.
Old 25th August 2011, 05:48 PM   #15361
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by simon7000 View Post
microdiodes that create bandwidth changes or other distortions.
Forgot about those. Just finished my 130dB gain instrumentation preamp. The 1nV noise almost rails my A/D and no spurs above the noise over 700Hz on heavily averaged 65K FFT's. Haven't tried batteries yet but the line noise residue is pretty low on a cheap supply (5nV spur at 180Hz) I'm ready to begin my search. I bet you can't wait.
I used the THAT 1512 based pre-amp from one of our sponsors. At $79 complete I couldn't see spinning a board and sourcing all the parts. Very few mods were needed (It had a 20MHz whistle on the LM317 when not in their manifold due to probably some external bypassing or not using their external PS.)
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 25th August 2011, 06:41 PM   #15362
simon7000 is offline simon7000  United States
Scott,
Just since you don't remember I have done the microdiode copper wire experiment. I measured the distortion in a copper strip then heated it until lots of oxides formed, let it cool and the distortion stayed the same.
In mechanical contacts it turns out the issue is not gaps but sulfur contamination. The silver or copper sulfide causes the molecules to grow a bit and hold off the mechanical contact. Application of voltage if the growth is not too thick causes ion migration and restores the contact. This shows up as no conduction until enough current and voltage to restore the contact and then if left unused the sulfur ions grow back.
ES
Old 25th August 2011, 06:52 PM   #15363
Pano is offline Pano  United States
Pano's Avatar
1,2,3
2,3,4
3,4,5
4,5,6
5,6,1
6,1,2
1,3,4
5,6,2
1,4,5
2,4,5
6,1,3
1,2,4
3,5,6
I see 18 possible groupings. Or 3x6.
Old 25th August 2011, 06:54 PM   #15364
Which did I miss? 3 x 6 -5 duplicates!
Old 25th August 2011, 07:00 PM   #15365
Pano's Avatar
I think these are the groups. Any dups?
123
124
125
126
134
135
136
145
146
156
234
235
236
245
246
345
356
456
Old 25th August 2011, 07:00 PM   #15366
Scott,
ES
Yes, I will repeat some of these experiments. The above explanation does not work for the sine wave plots with a dead zone at each crossing, and you should at least have a disclaimer on the speculative nature of this.
I would oxidize two bare wires and twist them together to see any effect and I STILL don't picture what you mean by the "distortion in a copper strip". Where is signal forced and where is voltage measured. I find it hard to believe a four wire measurement on a bar of copper shows any distortion.
Old 25th August 2011, 07:04 PM   #15367
On Hiatus
SY's Avatar
123
124
125
126
134
135
136
145
146
156
234
235
236
245
246
345
356
456
Yes. Remember, if you pick 123 you've eliminated 456. As long as you don't care which group is which, those choices are degenerate.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 25th August 2011, 07:05 PM   #15368
Let me know and I will send you the actual part I used in that test. (Assuming I can still find it!)
I also have samples of the old 1N4004 diodes that made so much switching noise that people started to notice it!
Old 25th August 2011, 07:07 PM   #15369
Pano's Avatar
Right, got it.
Old 25th August 2011, 07:35 PM   #15370
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
Originally Posted by Steve Eddy View Post
Fair 'nuff as long as the groups don't have to be identified.
se
That'll be Part II
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
