The Lounge A place to talk about almost anything but politics and religion.
Old 24th September 2009, 05:49 PM   #1521
bogdan_borko is offline bogdan_borko  Serbia
bogdan_borko's Avatar
This is what I got in simulator PMA used! It`s my version of complementary jfet/bjt preamp circuit with NO global negative feedback. The circuit needs buffer because the output is (10K) resistor loaded like in a JC2 preamp, so results of simulation are without output buffer.
That would be 0.00016% second harmonic for a 3V peak output for a single ende in/out and a much less for a balanced outout!
Old 24th September 2009, 05:50 PM   #1522
john curl is offline john curl  United States
john curl's Avatar
Well, it looks like everybody 'fell off the truck'. Could it be that schematics are intimidating? Or just too simple to bother with?
However, this is the question: How do you make a differential pair (of any active device) that is both lowest distortion and lowest noise (especially over a broad range of input impedance)?
Second question, how can you extend the S curve (always present in differential pairs) so that you are not hard limited by 2 Id ?
Three, who invented this first? and how many decades ago?
"Condemnation without Examination is Prejudice"
Old 24th September 2009, 06:09 PM   #1523
PMA is offline PMA  Europe
PMA's Avatar
John, I would like to ask a 'practical' question. Is there a big difference between my simulation results, for some 2.8Vpeak output amplitude, and your measurement on a real circuit? Also, is there a big difference between simulation and measurement in spectral content for SE and balanced input drive?
http://www.diyaudio.com/forums/the-lounge/146693-john-curls-blowtorch-preamplifier-ii-post1931538.html
Old 24th September 2009, 06:24 PM   #1524
john curl's Avatar
I don't think so, Pavel. I got .02% harmonic distortion at 2.5V out, with 3rd dominant and 2n'd about 20db below third, at 4KHz. This, of course, is beyond clipping level of my JC-1 or similar power amps or about 800+ watts output/channel into my loudspeakers with the JC-1, so it should be a high enough level for consideration.
Old 24th September 2009, 06:55 PM   #1525
Wavebourn is offline Wavebourn  United States
Designer & Technologist
Wavebourn's Avatar
I personally jumped out of the truck because I expected something exceptional, but found, like in a story, "a new patented way to screw the bulb", when the main device stands on the stool, puts the bulb into a socket on a ceiling, 4 devices helping it take each leg of the stool and start going in circles screwing the bulb; 4 (or more) additional devices go around in circles just to save the main screwing device from dizziness.
I personally would prefer just one device screwing the bulb by hands.
The Devil is not so terrible as his math model is!
Old 24th September 2009, 07:03 PM   #1526
zinsula is offline zinsula  Switzerland
zinsula's Avatar
Hello John, I only know the third question
One question I'm wondering since some time....
Which of the shown variants of input differential would you prefer (I think you used both?)
Thanks, Tino
If you can't trust your ears, then CLICK HERE
Old 24th September 2009, 08:59 PM   #1527
john curl's Avatar
A is easier to implement because of gain scaling. I suspect that they are about the same in linearity. The reason for this is that it is best to operate at the highest level of operating current, and A allows this, yet allows gain reduction.
Old 24th September 2009, 09:23 PM   #1528
john curl's Avatar
To be fair, a differential pair of vacuum tubes, such as the 7788, with variable screen regulators and properly designed by a real engineer, can do amazing things in terms of distortion. If you what to know more about this configuration, please contact Bascom King, of Santa Barbara, CA USA, as he helped design this configuration. It is not as quiet as fets, but the dynamic range is at least, the same as the best 4 jfet configuration.
Even a single triode tube, operating open loop, can be very good, as shown by the Audible Illusions line stage, if you want to not use differential input.
The real advantage of the 4 quadrant configuration over other approaches is the self biasing aspect, so that the S curve can be extended, and linearized, especially at extreme current swings. The differential pairs are in parallel, so the noise floor can be 3dB lower.
The biggest weakness is that the p channel fets have more capacitance for the same amount of transconductance i.e. Gm, and this can get in the way of extremely high Z input operation.
Old 24th September 2009, 09:30 PM   #1529
anatech is offline anatech  Canada
anatech's Avatar
Hi John,
Fewer active devices in the signal path running at higher currents. Reduce supply voltages (so things run cooler and a selected optimal point) and fix D-S (or C-E) voltages to prevent modulation effects from the supply voltages varying.
My guess for the first question. If you look at RF devices, they are almost always far more simple than audio parts if you look at # of active devices in the signal path.
That's a good question, by I'd ask why there is a need to remove this limit? Just work within it, and if your bias currents are high, it's very unlikely you would even approach 1 ID. After all, limiting the signal current to a smaller fraction of the operating range buys you a more linear transfer curve anyway. Once you begin to approach the complete operating range of current swing, you are creating your own problems to solve. I think that may force you to a more complicated way of maintaining linearity, and that seems to be opposite to the direction you normally would design in John.
No idea. I would suspect that there are examples (in a Bell lab somewhere of) almost every way to deal with an audio signal. Remember that before feedback amplifiers were designed, everything they did was open loop and tubes.
This is all solidly before I was born in the late 50s.
-Chris
Edit: Hey John, we were posting at the same time.
What would be interesting are some papers on this subject, rather than a look at how one man performed this design. Again, Bell Labs may have something here. Did Bascom King ever work for Bell? I'm not familiar with him or his work that I know of.
"Just because you can, doesn't mean you should" my Wife
Old 24th September 2009, 09:41 PM   #1530
Joshua_G is offline Joshua_G  Israel
Joshua_G's Avatar
John,
Indeed, jfets are quieter, however, aren't tubes more linear?
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
