The Lounge A place to talk about almost anything but politics and religion.
Old 14th July 2011, 05:17 PM   #14001
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by ThorstenL View Post
To be honest I don't subscribe to "Belting".
But if that is what you believe in, I'm happy to respect your deeply held beliefs...[/QUOTE]
Not my deeply held belief.
I'm just wondering why it's not one of John's. It's been shown to "work" by the exact same measure other things, such as not using steel chassis have been shown to "work."
It "sounds better."
se
The Audio Guild
Old 14th July 2011, 05:23 PM   #14002
On Hiatus
SY's Avatar
Steve, here's your problem: you don't know the difference between the Judean Popular People's Front and the Popular Front of Judea. Easy mistake for a novice, but please don't rile up the villagers any further.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 14th July 2011, 05:35 PM   #14003
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Steve,
Well, if that is what you are doing, have fun.
I wonder if you could explain why reasonably well aged "generic" (e.g. what comes in the box with most cheap gear) cables do not measure like a loopback using RG-223/Mil on HD?
Ciao T
Most cheap gear does not come with RGB/YPrPb or HDMI cables. Do you mean taking the "red-white-yellow" set and using it for HD? In that case I could understand.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 14th July 2011, 05:37 PM   #14004
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Scott,
Originally Posted by scott wurcer View Post
Most cheap gear does not come with RGB/YPrPb or HDMI cables. Do you mean taking the "red-white-yellow" set and using it for HD? In that case I could understand. BTW Netflix has an 11min. 24FPS HD video demo up on their instant view server, no info why.
HD = Harmonic Distortion
Ciao T
Old 14th July 2011, 05:39 PM   #14005
Steve Eddy's Avatar
Not sure why they should have theirs checked, it looks okay. Mine looks very similar on loop back if I use well screened cables that do not use steel center conductors.
The cables with the steel center conductors measured no differently than those with pure copper wires.
se
The Audio Guild
Old 14th July 2011, 05:43 PM   #14006
simon7000 is offline simon7000  United States
se
If you can't measure any difference that often is an indicator your test is not sensitive enough.
There are no freaking microdiode effects. I have deliberately add copper oxides to a conductor and after cooling the distortion did not change.
However there are microdiodes the Leprechauns keep them next to the pot of gold.
Old 14th July 2011, 05:51 PM   #14007
But Ed you showed pictures of sharp discontinuities in conductivity. The VI curves you posted will rectify (if they really exist).
My misread Thorsten
Old 14th July 2011, 05:54 PM   #14008
DF96 is offline DF96  England
That's because your test equipment is full of cheap nasty copper, which hides the effect.
Old 14th July 2011, 05:57 PM   #14009
My misread Thorsten
The curves you refer too are not microdiodes. Lets be clear that diodes always conduct although it is not linear as per voltage versus current. There is another issue (dead zone) and when I get a bit more along I'll show more.
The issue of oxide's forming diodes was a specific cable test and there were no changes noted at a level at which distortion in the interconnects was noted.
Old 14th July 2011, 05:57 PM   #14010
Steve Eddy's Avatar
Yes. Gotta get some ultra pure, single crystal, Ohno continuous cast copper wire.
Cryoed of course.
se
The Audio Guild
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
