John Curl's Blowtorch preamplifier part II John Curl's Blowtorch preamplifier part II - Page 1387 - diyAudio
The Lounge A place to talk about almost anything but politics and religion.
Old 13th July 2011, 05:59 AM   #13861
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by john curl View Post
Perhaps, Steve. And perhaps not. Everyone else, just tap your audio and video equipment with your fingernail and hear what happens.
Oh it'll ring like a bell alright.
Just because it's thicker and therefore stiffer, it doesn't mean it's less resonant. It'll be quite resonant. You telling me you've never struck a thick piece of aluminum before?
se
The Audio Guild
Old 13th July 2011, 06:01 AM   #13862
john curl is offline john curl  United States
john curl's Avatar
Just my preamp, Steve.
"Condemnation without Examination is Prejudice"
Old 13th July 2011, 06:25 AM   #13863
john curl's Avatar
The CTC Blowtorch was built to try to make the very best simple preamp that we could make. Did we go too far? I don't think so, but we could 'cut a few corners' and still have an acceptable preamp. For example, the last 7 preamps that I personally had to put together, used quality copper wire, rather than silver wire. The sound was good, but slightly softer than the pure silver wire. I did an A-B test, myself.
Old 13th July 2011, 08:02 AM   #13864
jan.didden is online now jan.didden  Europe
jan.didden's Avatar
se
You can make an enclosure thicker, heavier, put braces in, and the only thing you change is the frequency at which it rings. Speaker manufacturers discovered that a century or so ago
jan didden
Music is dither to the brain; lets me think below the usual chaos - me
Linear Audio Vol 13 is out! Check out my Autoranger and SilentSwitcher
Old 13th July 2011, 08:40 AM   #13865
Groove T is offline Groove T  Switzerland
Groove T's Avatar
Originally Posted by scott wurcer View Post
If you're DIY why not use fusable links of silver wire?
I make service for broken hi-fi gear, otherwise this would maybe not be a bad idea basically.
But my earlier boss saved some money due repairing broken fuses in some Conrad Johnsons with a piece of copper wire, calculated with magic cubes . They used BUSS fuses, very expensive, but safe and tehy said, the sound is better,
After the cheap fuse fix we often had blown circuits and output tubes....
I have seen some products with circuit breakers( Rowland) , because they found this the better sounding solution.
I have seen krells with regulated power supply, using dc sensors and similar protections instead of output fuses, the claimed ist sounds better.
Unfortunately they used fuses in the regulator power supply, which did NOT blow off when a capacitor there had a shortcut. This resulted in a burned stand by transformer ( this thingie sucked more than 90 Watts in standby and had no thermal protection) and the capacitor burned a hole into the board. Finally the main circuit breaker stopped the smoke and prevented a fire.
I have seen big Thresholds, when they failed, the output fuses protected themself while the output devices shortcutted themself and then the main circuit breaker did their job.
In the end, for the sound i feel its the best to avoid fuses whenever possible, without supressing safety of course.
Old 13th July 2011, 08:48 AM   #13866
Rod Coleman is offline Rod Coleman  United Kingdom
работник
Rod Coleman's Avatar
jan didden
OK, but what about the effects in the real application?
Consider two preamps, mounted on similar shelves. One has a Heavy, stiff chassis, one has a consumer-grade 0.7mm thick chassis, maybe with enough stiffening to prevent it from twisting when you pick it up.
Fire identical acoustic waves from a loudspeaker at each, from say 2m.
Which chassis transmits more of the incident acoustic energy to a circuit board inside the chassis, mounted on identical pillars?
Old 13th July 2011, 09:19 AM   #13867
jan.didden's Avatar
Don't know, and I would venture that none here have really looked at this in some systematical way.
Then again, what would the effect be of the vibrations on the PCB? How about all that presumably high-end stuff with mains transformers mounted on a PCB? Or, (gasp) mains transformers mounted on the chassis, using the chassis as a sound board?
Point is, there so much speculation here it would put a stock exchange veteran to shame
jan didden
Old 13th July 2011, 09:50 AM   #13868
EUVL is offline EUVL  Europe
I wonder if you would be interested in energy or vibration amplitude (displacement)..
In any case, energy is force x displacement.
Force is pressure x area, so same in both cases, I assume.
Vibration amplitude is less for higher masses and higher stiffness for the same force.
As a first approximation, you can assume that the PCB will follow the case, vibrationally.
Guess you can draw your own nconclusions.
Patrick
Old 13th July 2011, 10:04 AM   #13869
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
You may venture.
Measurable additional noise at the mains frequency and multiples. It is often mistaken for being due to electrical/magnetic pickup and one can spend amusing lucubrations trying to reduce them...
Well, there one often gets a lot of noise being radiated by these sound boards.
I once walked into a shop, being really annoyed by the loud buzzing noise. I eventually traced it to BOTH of the very big and very expensive M..... [brand deleted to protect the innocents] monoblocks...
Indeed, the problem is there are too many here intend on scoring points in the defencing (I use the archaic form of the word on purpose) of indefensible positions (like that all that High End stuff is BS, that cheap components are as good as expensive ones, that thin sheet metal chassis are as good as more solid ones and that everything sounds the same anyway).
If they actually occasionally stopped to think about things and asked themselves some questions they might find that the world is by far more complex and as a result interesting place than they imagined...
But most prefer false certainties to true uncertainties...
Ciao T
Old 13th July 2011, 10:10 AM   #13870
работник
Patrick
I think you can, too.
The stiffer, higher mass chassis face will reflect greater proportion of the incident energy. The flimsy chassis will be displaced, and transmit energy to the internals mounted to them, and reflect less.
Whether one believes this matters is up to the designer of the product.
John clearly believes it is important, and so would-be designers of high performance audio may do well to investigate it further, and decide for themselves whether it is worth pursuing. To be clear, I do not suggest that one should copy what John does, but to investigate, weigh and consider.
The effect upon various capacitors, and other components of acoustic energy has been noted here and widely elsewhere, and would be part of the evaluation.
So, Jan, there may be some speculation involved to begin with, but product design often begins with speculation. It's what you do next that counts - evaluation, comparison, redesign, and testing the finished article for fitness for its intended purpose. John's doing something right.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
