The Lounge A place to talk about almost anything but politics and religion.
Closed Thread
Old 15th March 2011, 09:27 PM   #11381
wrinkle is offline wrinkle  United Kingdom
Pickling is usually used to remove the oxide film that is created when the material is annealed to reform its mechanical properties.
My Father briefly worked in a wire rope factory after he graduated. The pickling tank was made of Iron Wood sawn logs held tight with hastelloy bolts, the pickling solution was hot aqua regia. The neighbourhood used to get their washing on the line falling apart from the fumes.
And on a smaller scale I have used sulphuric acid and electrolysis to remove burrs from 316 stainless capilliary tubing.
Wrinkle
Old 15th March 2011, 09:36 PM   #11382
jneutron is offline jneutron  United States
jneutron's Avatar
Originally Posted by simon7000 View Post
About the only issue that it did not make completely clear was why increasing the inductance of the transatlantic cable helped to carry the signal. Most folks would have assumed that the increased inductance would decrease the signal strength.
Nah, that'd be too easy...
The transatlantic cable problem was one of propagation velocity vs frequency. It was found that the velocity of audio frequencies on the long lines was variable enough to cause lots of distortion. By increasing L, it was possible to diminish damping..
They also found that the minimum damping was reached when:
Rsqr(C/L) equaled Gsqr(L/C).
This made the wave velocity independent of frequency..
Cheers, John
ps..I cheated..
Becker, Electromagnetic Fields and Interactions, 1964, page 262..
pps..hey, at least I remembered it was there...I get points for that, no??
Old 15th March 2011, 09:46 PM   #11383
jlsem is offline jlsem  United States
jlsem's Avatar
It wasn't they, it was Oliver Heaviside.
John
Old 15th March 2011, 10:21 PM   #11384
jneutron's Avatar
John
Oliver whooviside??
Yo...gimme a break, all I got's is dis stinkin book by Becker...whaddyawant from me anywhoo..???
Cheers, John
Old 15th March 2011, 10:38 PM   #11385
simon7000 is offline simon7000  United States
Cheers, John
ps..I cheated..
Whoo,
At least you did reveal what G means. Next you will give out the secrets of "repeat" coils and constant loading.
Right now we have almost anyone able to draw a schematic and simulate results. If we reveal the basics in the historic context, quoting papers anyone can follow, it will give THEM the well rounded context to actually understand not just what happens but why.
Look the purpose of this thread is to poke fun at JC when he tells people what has worked for him in the past and for him to explore options without having to reveal exactly what he is working on. If you, Scott & SE keep giving away the hidden secrets, that will reduce the venom often shown here, and things might get cleanly technical. As we all know that means boring.
Pavel, Demian, Bob, Jan, etc at least you haven't leaked any real secrets here.
ES
Old 16th March 2011, 12:55 AM   #11386
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
So I guess we all agree that the noise generated at a specific frequency will be dependent on the Rs component of the Ls-Rs model?
Cheers, John
This is truely silly we always agreed. Now if only you would buy into the fact that an inductor in a box would have self noise commesurate with the eddy current losses.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 16th March 2011, 12:57 AM   #11387
john curl is offline john curl  United States
john curl's Avatar
I'll light YOU up Jam, if you don't read that paper that I sent you. '-)
"Condemnation without Examination is Prejudice"
Old 16th March 2011, 02:24 AM   #11388
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
John, i have something to ship you. Wanted to build the beatle phono stage into it. No time.
Old 16th March 2011, 03:35 AM   #11389
john curl's Avatar
Don't worry about it Joachim, I have my Porsches.
Old 16th March 2011, 04:44 AM   #11390
jam is offline jam  United States
jam's Avatar
Yeah........but some people consider a 944 a Volkswagen!
Jam
Closed Thread
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
