The Lounge A place to talk about almost anything but politics and religion.
Old 11th March 2011, 03:50 PM   #11021
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by gpapag View Post
Emphasis was on the "Losses" to make clear that the linked document deals with Eddy Current Losses only, with no hint of inference to Eddy Current Noise.
Ok. I just didn't understand why you made mention of it again since there was never any disagreement regarding eddy current losses.
But reading your:
I was (and still Iím) under the impression that you were pulling a leg toward the skin effect and proximity effect (which are actually describing the action of eddy currents within the circuitís current conductor own material).
If I failed to read correctly your message, my apologies, but please explain your messageís reasoning.
All I was saying was that the thermal noise of a simple length of wire should also exhibit a frequency dependent level due to eddy current losses, i.e. skin effect.
A simple length of wire such as the phono cable connecting the turntable to the phono stage.
se
The Audio Guild
Old 11th March 2011, 04:12 PM   #11022
Steve Eddy's Avatar
Originally Posted by john curl View Post
Sooner or later, eddy current losses and their effects will be better understood by my 'critics' here. One only has to measure the Q of the coils with frequency to understand it almost completely, and of course, that is what I was specifically looking for in my quest in the JAES for a graph that was clearly defined and explicit.
More meaningful would be to actually quantify it in a moving coil stepup transformer instead of making blanket statements that any such transformer that's using 13 mil laminations is crap and not worth considering.
se
The Audio Guild
Old 11th March 2011, 05:01 PM   #11023
Soundminded is offline Soundminded  United States
Originally Posted by DF96 View Post
With regard to eddy current losses, one way to think of these is to add an extra winding to the transformer then put a resistor across the winding. This represents both a loss mechanism, and a source of thermal noise. The thermal noise is present whether there is a signal or not.
However, this might not be a perfect analogy as eddy current losses increase with frequency but a loaded secondary is flat. Perhaps a better analogy would be a loosely coupled secondary, so that the induced voltage rises with frequency but there is only a weak back reaction onto the primary.
Eddy current losses are losses generated inside the ferrous core due to induced circulating currents. They are in a direction transverse to the magnetic field. This is why cores are laminated and insulated from each other electrically. The thinner the laminations, the less the losses for a given alloy.
Hysteresis losses are losses in the core due to the inefficiency of the coercive field to produce a corresponding induced field. At first application the curve is extremely non linear much like one of the family of characteristic curves of a triode. It curves slowly up from zero and then rises steeply and linearly. Once the magnetic domains are in motion, the retrace is usually linear but the curves in opposite directions don't coincide. The area between them is a measure of hysteresis loss. Short fat curves that are widely separated are characteristic of material that is poor for most transformers and inductors (saturable core reactors used in some circuits may be an exception.) Tall nearly vertical curves that are closely spaced such as for supermalloy are best.
Hysteresis and eddy current losses can be eliminated completely by building air core transformers. However, the lack of a core to concentrate magnetic flux may reduce the overall efficiency of coupling the primary and secondary windings. This might still be the best option...if you have to use a signal transformer. It seems to me that with low noise transistors, you have a far better choice.
Old 11th March 2011, 05:34 PM   #11024
PMA is offline PMA  Europe
PMA's Avatar
When I am designing Constellation
It has always been my favorite
Old 11th March 2011, 05:34 PM   #11025
gpapag is offline gpapag  Greece
gpapag's Avatar
Originally posted by jneutron
Eddy currents do not couple back in this direct fashion, so I would not use this method. (good thinking however, I also considered this test but after thinking a while, understood the limitations.)
What is needed to evaluate this is:
1. Wind 4 C cores with pickup windings. One core solid iron, one 1 mm laminations, one 1 mil laminations, and one comprised of ferrite.
2. Excite the core using a rotating neodymium magnet. The drive must be low noise.
3. Examine the output waveforms for indications of noise amplitude consistent with frequency.
John, may I propose an easier to implement set-up for testing the eddy current induced signal noise idea?
Take 3 small 1-2 Watt cheap power E-I transformers, all of the same type, from the same manufacturer.
Dismantle them, one at a time.
Leave the laminations of one as is(actually, no need to dismantle this one).
Remove the electrical insulation from half the laminations of the second.
Remove the electrical insulation from all the laminations of the third.
Clean the laminations.
Reinstall the coil bobbins and reassemble the transformers.
Apply a signal to the primary (10KHz-20KHz ?) and record (the properly terminated) secondary voltage from each transformer. Better still to simultaneously record the primary voltage as well.
This test can be accomplished with only one transformer. Three measurements again, but the first with all laminations as is, the second with half the laminations stripped from insulation and the third with all laminations stripped.
(Edit:Regardless if one or three transformers are used,) on the three measurements, core eddy current losses will be different. Core hysteresis losses will be the same. Wire losses of any kind will be the same.
George
["Second Law is a bitch." - SY] ["BTY my shop's large door is 14 feet wide so I can get my ego in each morning. Some evenings it can leave via the mail slot". -Ed Simon]
Old 11th March 2011, 05:48 PM   #11026
mrfeedback is offline mrfeedback  Australia
mrfeedback's Avatar
The perceived nature of the total noise in any system is the criterion......an add-on that reduces perceived and measured N&D is the nirvana - this is possible and proven.
Eric.
I believe not to believe in any fixed belief system.
Old 11th March 2011, 05:49 PM   #11027
jneutron is offline jneutron  United States
jneutron's Avatar
It is not noise caused by the presence of eddy currents, but noise caused by the possibility of eddy currents. The simple fact that there is an energy dissipation mechanism present is sufficient to create thermal noise from that mechanism. The mechanism does not have to be dissipating energy from a signal. The mechanism just has to exist. That is all. Just like a resistor; its thermal noise does not depend on the voltage across it, just its temperature.
The "possibility"? Shirley you jest...next you'll be tossing a cat in a box..
Let's extend your argument, shall we?
Take the 4 cores I mentioned earlier. Put all 4 in an isothermal, zero field box, with only the wires exiting the box. Your statement ""The simple fact that there is an energy dissipation mechanism present is sufficient to create thermal noise from that mechanism means that I should be able to distinguish the core design by examination of the terminal voltage despite the fact that there is no external excitation.
Therefore, the one with the higher terminal voltage is the one that has the possibility of eddy currents.
While not exactly Maxwell's demon, you come close. You postulate that despite the total lack of a magnetic field to couple the coil to the core, it knows nonetheless..
I'm not buying it..
Current does not produce shot noise. It is uncorrelated discrete charge carriers which create shot noise. Almost all currents use highly correlated charge carriers, so no shot noise.
Hmm...for some reasons, my textbooks do not agree with your statements.
Please explain the difference between correlated discrete charge carriers and uncorrelated discrete charge carriers...in a metal.
The exception is when charge carriers have to cross a potential barrier, which shields them from each other and reduces correlation.
Are you talking conduction and valence bands?
As Q is a measure of dissipative loss, it will correlate with thermal noise.
Yup...I did say that earlier as well.
If John Curl measures lower Q and hears more noise, then that suggests that the noise is thermal in origin. If he also finds that thinner laminations give higher Q and less noise, then it is quite likely that the mechanism is eddy current losses.
Said that as well...so I guess we agree?
Originally Posted by scott wurcer View Post
Carver Mead argues to the equivalence of the two (just to add confusion).
This is a good read.
http://www.rle.mit.edu/avbs/publicat...journal_16.pdf
Nice read. Thanks for the link.
Funny, yesterday I was thinking of the old slide the supermagnet down the copper pipe experiment but you could never get the stiction noise low enough. I would try dropping the magnet in a vaccum.
You are very close!!! (ran for lunch, had time to think)..
Take a C shaped laminated core which has two neo magnets and a 1/2 inch wide gap such that the flux crosses that gap.
Wind a pickup coil around the back leg of the C such that any variation in the permeability of the gap will produce a voltage on the coil.
In steady state, the coil voltage will be only thermal noise..
Now, build a long arm with a copper blade much like a sythe, pivoted such that only the copper blade passes through the flux gap.
Any additional noise pickup by the coil is a direct result of the eddy current loss mechanism of the copper.
Easy as pie..where's my invite to Sweden...
Cheers, John
Old 11th March 2011, 05:56 PM   #11028
jneutron's Avatar
John, may I propose an easier to implement set-up for testing the eddy current induced signal noise idea?George
Not bad, I like the way you think.
Practical problems:
Cleaning the glue off the laminations.
Packing density.
Noise from the current source.
Proximity effect based noise in the wires (the increase of Rs with frequency.)
I was thinking along the v drive line as well, but decided I could remove the current induced noise of the primary by using a rotating magnet. Yes, I would then have to contend with the bearing noise of a pair of ABEC 9 unsealed bearings in a vacuum connected to a flywheel. But what the heck, this is all thought experiments anyway...
Cheers, John
Old 11th March 2011, 06:06 PM   #11029
On Hiatus
SY's Avatar
Well, don't the coils have Johnson noise? So that, except at 0K, the core is getting excited.
edit: To be clearer, the fact that the box is isothermal means that there has to be energy removed from it by external means.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 11th March 2011, 06:10 PM   #11030
Steve Eddy's Avatar
I was thinking of something similar.
If what jcx says is true, i.e. that that noise would be independent of signal level and would be manifest even in the absence of a signal, then to quantify noise due to eddy current losses in the core it should be a simple matter of measuring the high frequency noise in an existing transformer and compare that to the calculated noise based on simple winding resistance.
se
The Audio Guild
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
