The Lounge A place to talk about almost anything but politics and religion.
Old 6th March 2011, 06:36 PM   #10701
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Originally Posted by gray5596 View Post
Steve, if you put this pre-amp in a limited edition Altoids case, cryo it, critics will have ear-gasms and you'll be able to double the price!
Sorry, but there's no evidence that any two reasonably well designed mint tins sound any different.
se
The Audio Guild
Old 6th March 2011, 06:46 PM   #10702
john curl is online now john curl  United States
john curl's Avatar
A more important question is: Is the case, aluminum or steel?
"Condemnation without Examination is Prejudice"
Old 6th March 2011, 06:52 PM   #10703
john curl's Avatar
How about a photocell on the top of the case that charges an ultracap, that supplies the led? Now, THAT is engineering!
Old 6th March 2011, 07:03 PM   #10704
Steve Eddy's Avatar
Steel of course. Which provides good magnetic shielding.
se
The Audio Guild
Old 6th March 2011, 07:04 PM   #10705
Steve Eddy's Avatar
Nah. The ultracaps have too high an ESR. The light doesn't look as good compared to being supplied from a good low impedance power supply.
Oh, and a photocell won't charge anything.
se
The Audio Guild
Old 6th March 2011, 07:13 PM   #10706
john curl's Avatar
Steel! Let's measure the added distortion!
Old 6th March 2011, 07:23 PM   #10707
john curl's Avatar
Ultra caps can power flashlights, they can easily do a pilot led.
Old 6th March 2011, 07:36 PM   #10708
PMA is offline PMA  Europe
PMA's Avatar
I mentioned it several times in this thread.
http://www.diyaudio.com/forums/analo...ml#post2403966
Old 6th March 2011, 08:42 PM   #10709
scott wurcer is offline scott wurcer  United States
scott wurcer's Avatar
Originally Posted by jcx View Post
can the new processes keep the 1/f corner down - assuming anyone wanted to "spend" enough area on the input Q to try to match your 797 or 743 designs?
That is a managable problem (the details would escape most here). One of the issues is double epi and engineering in the low noise in the first place. These processes were optimized for speed (in hindsight, blindly), TI gave a paper at this ISSCC on an SOI JFET amp with 8nV at 10Hz. We are on it (I am just a vociferous fly on the wall for this project), keep tuned. The geometries have shrunk to the point that the area is not an issue. The 743/45 was a big risk experiment, the fact that GE ran a whole generation of CAT scanners based on it, saved it. I'm not sure if I could get away with a sub 3nV FET amp in this market again.
"The question of who is right and who is wrong has seemed to me always too small to be worth a moment's thought, while the question of what is right and what is wrong has seemed all-important."
Old 6th March 2011, 09:17 PM   #10710
In fact the AD745 is my own personal IC Blowtorch, probably a reasonable portion of them ended up as RIAA's.
John Curl's Blowtorch preamplifier part IIHide this!Advertise here!
Copyright ©1999-2017 diyAudio
