The Lounge A place to talk about almost anything but politics and religion.
And what did we buy today?
Old 7th July 2018, 03:02 PM   #1341
Dave R is online now Dave R  United States
Dave R's Avatar
Originally Posted by planet10 View Post
You have to bring them to diyFEST?
dave
Will do.
I'm also adding a pair of 15" U-frame bass units, as these coax drivers only reach down to 90~100 Hz by themselves. The bass units will be included for the PNWAS speaker contest, but may not have room for the carpool to diyFEST. I'll see if I can make them more portable (maybe screwed together flat pack?). hmmm . . .
- Dave R
the 200% Norske
Old 12th July 2018, 09:06 PM   #1342
ODougbo is offline ODougbo  United States
Best circle cutters made for 8'' holes and smaller.
70 years old - hard to believe.
Made in Beverly Hills California (and I was just there btw).
Old 12th July 2018, 11:13 PM   #1343
nigelwright7557 is offline nigelwright7557  United Kingdom
nigelwright7557's Avatar
Ordered a pcb for my own design digital PC USB scope today from PCBWAY.
Ordered the parts for the pcb from Farnell and RS Components.
I am using a PIC32 that runs very fast and has a fast a2d converter.
I am using Microchip Harmony for the basic software so will be interesting to see if I can get it to work.
I am more used to 8 bit processors and the PIC32 is full of 32 bits registers with special function registers that need every bit set correct to work properly.
Keeps me out of mischief.
PCBCAD51 pcb design software. 2018 version out now with lower prices >> http://www.murtonpikesystems.co.uk
Old 12th July 2018, 11:16 PM   #1344
Pano is offline Pano  United States
Pano's Avatar
I've owned a couple of hole cutters like that - but more recently made. Never had good luck with them. Yours work well?
Take the Speaker Voltage Test!
Old 13th July 2018, 09:30 AM   #1345
yngvejos is offline yngvejos  Norway
yngvejos's Avatar
Bought a JBL flip 4 yesterday. Great little speaker to get some music on vacation.
Old 13th July 2018, 02:05 PM   #1346
Mr_Zenith is online now Mr_Zenith  United States
Mr_Zenith's Avatar
Can't speak for ODougbo, but I've personally had excellent results with both wood and aluminum using flycutters (as they're usually called). They can be extremely dangerous if used improperly, however.
The keys to success - and safety - are to:
  1. Only use these in a drill press, and make certain the blade is sharp.
  2. Clamp the workpiece securely to the press table, using a sacrificial surface underneath.
  3. Make certain that all adjustment screws are secure before tightening the chuck.
  4. Use a press speed (rpm) appropriate to the material you're cutting.
  5. Feed the cutting blade slooooooowly into the workpiece. Let the blade do all the cutting.
It does take skill, but with a little practice you can achieve excellent results - and without sawing your arm off (it happens)....
Old 13th July 2018, 02:58 PM   #1347
soundbrigade is offline soundbrigade  Sweden
soundbrigade's Avatar
Send a message via MSN to soundbrigade
I have been using them and they requires some work to work perfectly. I always drill/cut from both sides.
On one occasion, I left the drill unattended for a few minutes and when I came back, someone had changed the speed of the machine. I was EXTREMELY lucky that the cutter hit the wall behind the machine.
I did buy myself a bottle of red and a bottle of white wine (Italian) and a french soda (pamplemousse).
/Magnus
Due to economical cutbacks, the light at the end of the tunnel has to be switched off.
Old 14th July 2018, 12:42 AM   #1348
I use a piece of wood with two screws in to mark out my speaker holes.
One screw is driven into the centre of the baffle and the other left loose to score a circle. I then get my trusty jigsaw and carefully cut out the circle.
Only got caught out once when a Fane speaker spec gave the wrong baffle hole size ! so now I always measure the actual speaker.
Old 14th July 2018, 02:36 AM   #1349
TheGimp is offline TheGimp  United States
TheGimp's Avatar
$0.99/lb roasting hen.
Tasty.
If there are no dogs in Heaven, I don't want to go there.
Old 14th July 2018, 05:28 AM   #1350
leadbelly is offline leadbelly  Canada
leadbelly's Avatar
Went down to our "upper" Chinatown trying to get a ready-made Chinese birthday cake for my wife, but failed. Lots of cheap meat at the butcher though, my mother-in-law bought things like pigs feet and pork spine for the bargain sum of $71.
Then scored an old copy of The Calgary Gardener, Vol 2 to give her. Yes, we have our own book, you would not believe how hard our climate is on green things, despite being the sunniest city in Canada.
There are still unbridgeable divisions between cultures. How can two peoples ever come to understand each other when one of them is ignorant of TotÚ? Umberto Eco
And what did we buy today?Hide this!Advertise here!
Let's see, what did we DIY today? Magura Parts 7 5th June 2009 07:46 AM
Today was the Day EdT Class D 0 14th April 2007 12:23 AM
today being April 1st consort_ee_um Everything Else 1 1st April 2007 09:29 AM
Is www.41hz.com down today ? ashok Everything Else 2 25th August 2005 02:35 PM
