The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Amp Camp Amp Kit V1.6
Old 20th June 2018, 12:56 AM   #51
nycavsr2000 is offline nycavsr2000  United States
nycavsr2000's Avatar
Originally Posted by AVril View Post
Ddear friends:
A few questions from a newbie, if I may.
I understand each kit can be configured as a fully balanced mono-block with twice the power of the standard ACA, i.e. 2x8W into 8 Ohms per channel.
  1. Will the distortion remain at 0.7% at 1 Watt in this case?
  2. Each amp has 4 speaker terminals. In case of a mono-block, what two terminals should be connected to a speaker?
  3. Is my Primare PRE30 balanced preamplifier suitable to work with ACA mono-blocks?
Avril,
1) In the XLR mono block build, the ACA V1.6 will put out about 10 watts into 8 ohms (assuming 1% distortion). It will put out nearly 20 watts into 16 ohms.
The distortion at 1 watt with the above build is about 0.04% (distortion cancellation is advantageous here with the balanced design):
2) If you look at this post, it illustrates how to connect the speaker terminals in the XLR mono block build.
3) Assuming a standard design, I do not see why you cannot use your Primare Pre30 balanced preamp. This assumes that both pin 1 and pin 3 of the XLR outputs on your Primare Pre30 have a signal and judging from Primare's design document on their website, that appears to be the case.
Best,
Anand.
Old 20th June 2018, 02:28 AM   #52
6L6 is offline 6L6  United States
6L6's Avatar
AVril -
1) No. It gets significantly better, 0.04% 1W 8Ohm
2) The two blacks.
3) Absolutely!
EDIT- This post brought to you by somebody who didn't reload their open browser window after going to dinner... (Anand's answers are all perfect)
Old 20th June 2018, 07:03 AM   #53
plsvn is offline plsvn  Italy
more n00b question(s):
once built as bridged XLR, can v1.6 still be also used as
a. SE bridged mono
b. stereo
(obviously by changing pre/speakers connections accordingly)
thanks
Old 20th June 2018, 09:10 AM   #54
jaaptina is offline jaaptina
Originally Posted by nycavsr2000 View Post
Avril,
Thought it was 20 Watts into 4 Ohm?
Old 20th June 2018, 09:18 AM   #55
Measurements are a beautiful thing. I honestly do not know what the output power is at 1% for 4 ohms.
Remember this topic is about using the ACA as a bridged mono block amplifier and as such loudspeaker designs (and especially inefficient ones) with persistently lower impedances (3-4 ohm loads between 100 Hz to 5khz) are probably not recommended especially if higher power is desired.
But for 8 ohms and 16 ohms, see here for details.
Best,
Anand.
Old 20th June 2018, 01:29 PM   #56
6L6's Avatar
plsvn -
a. Yes
b. Yes
Old 20th June 2018, 02:55 PM   #57
thank you 6L6: that's great indeed
in the while... just got a shipping notice from ModuShop, meaning cases should be here tomorrow
Old 21st June 2018, 11:54 AM   #58
and... here they are
http://files.diyaudio.com/forums/images/attach/jpg.gif
Old 21st June 2018, 01:20 PM   #59
RafaPolit is offline RafaPolit  Ecuador
RafaPolit's Avatar
Lovely! Just another month for pieces and I guess we will start seeing a lot of pictures!
Old 23rd June 2018, 01:18 PM   #60
AVril is offline AVril
Thank you very kindly for your most appreciated help, dear friends!
Amp Camp Amp Kit V1.6Hide this!Advertise here!
Amp Camp #1 PCB Rudi_Ratlos Swap Meet 42 23rd April 2018 07:09 AM
Amp Camp amp tttubes The diyAudio Store 3 15th November 2016 01:57 PM
Amp Camp Amp GregBaker The diyAudio Store 0 11th January 2015 11:41 PM
Amp Camp! Jason Site Announcements 2 30th June 2012 02:57 PM
