The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 13th January 2018, 04:05 PM   #1531
gerhard is online now gerhard  Germany
gerhard's Avatar
I have tried the scope, that seems to work; otherwise I'm more
interested to use it as a software define radio. But I have put
it on hold, I must finish those low noise preamps first. I tend to
have more projects in parallel than I can handle.
There is a picture in the thread "No RF Gear here?" in the lounge.
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 21st January 2018, 01:49 PM   #1532
Manolo47 is online now Manolo47  Puerto Rico
Default Pass ba-3 line stage
is there a way to use this board for the ba3 as line stage power supply ie, with mods to bring the output to 24/-24v ? Thanks.l
Old 21st January 2018, 02:56 PM   #1533
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Super Regulator
Addressed by Jan a few pages back.
Old 8th February 2018, 04:39 AM   #1534
ammel68 is offline ammel68  United States
Banned
Super Regulator
Jan, I noticed in one of your replies in another PS thread, you stated that the 120uF caps in the "Super Regulator" should not have low ESR.
First...120uF caps aren't as common as 100uF caps.
Second...after doing some searches at Mouser, I came up with these 120uF caps which have a ESR of 514mOhms:
860020675017 Wurth Electronics | Mouser
I've never heard of or purchased Wurth caps before, but do you think they will work okay in the "Super Regulator"?
Thanks.
Old 8th February 2018, 11:02 PM   #1535
jackinnj's Avatar
Super Regulator
I have a bandelier of Panasonic FC -- 120uF/25V -- 200 pieces @ $0.40 -- how many do you need. NOS from Mouser.
The first electrolytics specified by WJ in the 1995 articles were quickly obsoleted. The Panasonic FC has also gone unobtanium in 25V, but generally available in 35V at the usual suspects.
Old 9th February 2018, 05:50 AM   #1536
Banned
Super Regulator
I certainly don't need 200 pieces, but it's good to know that you have a good supply.
My understanding is that the Panasonic FC, FM and FR caps are all low ESR caps.
Are you saying that low ESR caps will work just as well as higher ESR caps in the SR?
Old 9th February 2018, 08:12 AM   #1537
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Thanks.
The low ESR comment was for the cap on the output. This cap plays a role in the stability and should not be low ESR like some boutique film caps. This is most easily fulfilled by using any cheap electrolytic at that position.
The other electrolytics can be good quality and low ESR if preferred, but will have very little if any impact on performance.
Jan
Advertising is the rattling of a stick inside a swill bucket - George Orwell
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher
Old 9th February 2018, 04:09 PM   #1538
jackinnj's Avatar
Super Regulator
You only need 4 per regulator, for a total of 8.
Old 9th February 2018, 05:03 PM   #1539
jackinnj's Avatar
Super Regulator
I just put a 120uF/25 V Panasonic FC and a 35V version on the VNA so you can compare the ESR.
Old 22nd February 2018, 04:20 PM   #1540
RobLK is offline RobLK  United States
I'm about to order parts for a +15v super regulator. Looking at the schematic at the Diyaudio store I calculated R6 from the formula R6 = (Vout*R7/Vref)-(R7+R16). So If R7 is 1k ohm as in the schematic and Vref is 6.9v then R6 = (15*1/6.9)-1.1 or a 1.07k ohm resistor. Does this look about right?
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 31st October 2014 12:47 AM
Jung Super Regulator audionut Solid State 5 7th August 2009 02:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 11:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 03:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 08:31 PM
