The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 10th January 2018, 07:45 PM   #1521
jackinnj is offline jackinnj  United States
jackinnj's Avatar
Super Regulator
Mark -- will look at it on the bench this afternoon. Once you start getting into the weedy part of PSRR layout seems to become a critical issue.
Old 12th January 2018, 03:02 AM   #1522
DualTriode is offline DualTriode  United States
Mark,
You are speaking of spice results. If the spice results are 20% better than tested results then the spice circuit may have some merit.
While you are at it please run a simulation of the bootstrapped 317 and 337 pre-regulated Jung/Didden regulators.
My suspicion is that the simulation results will be somewhere near the 20% delta compared to the published Jung/Didden regulators results.
DT
Old 12th January 2018, 03:19 AM   #1523
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Super Regulator
Naaw. If it's important, you'll do it yourself. If it's not important, you won't.
If it's too difficult or too time consuming, that means: it's not important. If you can't be bothered to learn how to create and run simulations, that means: it's not important. If you are waaay too "over subscribed", if your normal day requires "multi tasking" far too deeply to even consider creating a simulation, that means: it's not important.
How important is it?
Old 12th January 2018, 07:11 AM   #1524
Default How important is it? Not so much.
Mark,
Thanks for the clever reply.
I thought that you could be persuaded to help make the point, you are a serious fellow.
Oversubscribed, not so much, I have been selling the peaks.
I am getting the idea that simulation can/does miss a lot. I recently put a new analyzer on the bench and have been testing the homemade creations from over the years.
It is amazing how the transformer/rectifier grunge and IM products get into everything.
If we were to specify minimum regulator performance, I am not sure what high frequency rejection would look like. In terms of the analyzer what weighting curve will we end up using? I am thinking about it.
I have not put LTspice on the new Intel coffee lake computer yet.
What is next; finish the Borbely FET line stage and roll in a few different regulators including the Silent switcher and see what the graphs look like.
DT
Old 12th January 2018, 03:15 PM   #1525
Super Regulator
Good. Maybe you might want to investigate Omicron's "Bode 100" (web link) test equipment. A couple DIYA members have one, and use it to extract the loop gain and phase plots of real hardware (amplifiers, power supplies, test gear, etc). Occasionally they upload the Bode 100 plots here. Looks like slick gear, and sidesteps many of the doubts & worries about simulations.
Old 12th January 2018, 03:44 PM   #1526
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
I'd rather lose an arm than my Bode 100... ;-)
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 13th January 2018, 12:38 AM   #1527
jackinnj's Avatar
Super Regulator
Jan
I found an old omicron application note on how to use it as an S-Parameter analyzer.
Old 13th January 2018, 07:12 AM   #1528
jan.didden's Avatar
Isn't that standard? Are you running the latest V3 software?
Jan
Old 13th January 2018, 11:27 AM   #1529
gerhard is offline gerhard  Germany
gerhard's Avatar
I've bought me a Red Pitaya for XMAS!
14 Bit, 125 MSPS, 2 ADCs, 2 DACs, network, USB, Linux, open source, cheap.
< Red Pitaya >
"That's right!" shouted Vroomfondel, "we demand rigidly defined areas of doubt and uncertainty!" "We don't demand solid facts! What we demand is a total absence of solid facts. I demand that I may or may not be Vroomfondel!"
Old 13th January 2018, 01:04 PM   #1530
jan.didden's Avatar
Gerhard, I have been ogling that also, Elektor had a deal on it recently.
Did you check out the measurement software - is it ready to use?
Jan
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
