The diyAudio Store A forum for discussing anything about the products available in The diyAudio Store.
Super Regulator
Super Regulator
Old 30th September 2017, 04:18 PM   #1451
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
Super Regulator
For those who seek a foolproof circuit that guarantees every possible Super Regulator with every possible choice of opamp, will start up correctly, 100.00% of the time, ...
... but who are horrified and nauseated by post #1146 which uses (gasp!!) a voltage regulator IC to start up a discrete voltage regulator, ...
then I offer the modification below. Parts count has exploded: there are now four components. A new resistor has been added. The blasphemous voltage regulator IC has been excised, and replaced with a theologically approved Darlington transitor. A discrete transistor. Ahhh, that's better.
Q1 and D1 should be rated for a continuous output current equal to, or greater than, the maximum load the Super Regulator might drive. Even though they are only active in the first few hundred milliseconds of startup behavior, it's better to be safe than sorry. I wouldn't go so far as to mount Q1 on a heatsink, however. There's overkill and there's ridiculous, indefensible overkill.
_
Old 9th October 2017, 03:58 AM   #1452
kamis is offline kamis  Serbia
I wish to use Super Regulators in Paradise phono stage I am built at the moment instead of proposed shunt regulators. It got better results in LA listening test article. I have the following op-amps: AD825,OPA134,OP604. NE5534, LME49710. Which one to use in this MC phono stage?
Old 9th October 2017, 12:32 PM   #1453
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
It doesn't really make a difference for the regulator whether to drive a phono stage or another small-signal circuit.
All the opamps you mention are suitable. My personal favorite is the AD825, never had any issues with start-up, always rock-stable. But it's a bit subjective, I admit.
Jan
Cable: a potential source of trouble interconnecting two other potential sources of trouble - Erik Margan
Linear Audio pubs and articles . The SilentSwitcher now at diyaudio store SilentSwitcher. Keeping in touch with SY.
Old 9th October 2017, 12:50 PM   #1454
Thank you, I will use AD825 , Walt Jung prefers it too.
Old 12th October 2017, 12:01 PM   #1455
couguarek is offline couguarek  Poland
How much additional current is taken by the regulator circuit ? In some cases it's important thing.
Old 12th October 2017, 02:56 PM   #1456
Super Regulator
If you post your calculations, I will double check them for you.
Old 12th October 2017, 03:59 PM   #1457
+/- 40V @ 70mA each rail
Old 12th October 2017, 06:10 PM   #1458
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
Super Regulator
The main contributors are the supply current from the opamp (found in datasheet), current through the voltage reference and through the feedback network.
AD825 typ. 6.5 mA
Reference 1-5 mA depending of design
Feedback 1-10 mA depending of output voltage and design
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 55 pcb's in order. 49 paid.
Old 12th October 2017, 06:12 PM   #1459
jan.didden's Avatar
Which opamp do you plan to use?
Jan
Old 12th October 2017, 06:32 PM   #1460
Jan
opa445ap
Super RegulatorHide this!Advertise here!
About Jung super regulator MaxS Power Supplies 125 30th October 2014 11:47 PM
Jung Super Regulator audionut Solid State 5 7th August 2009 01:07 PM
Super Regulator TheDriver Parts 2 21st July 2008 10:54 AM
Lithos regulator - A new super regulator? peranders Parts 7 8th May 2008 02:01 PM
Super Regulator for DAC rockytro Digital Source 11 19th May 2006 07:31 PM
